I like to run memtest for as long as it takes to complete the entire tests cycle, which is usually a few hours, but I like to let it complete the cycle 2-3 times. Since are just testing too see if there is an issue, you can test with all 4 sticks installed, then if you get errors you can test them individually. If your RAM is faulty, it will look like this:
