Memory Questions
Quick question. Will 2 separate 1x8 gb kits of ram run in dual channel or do I need to buy a 2x8 dual channel kit? Reason for asking; Newegg makes you buy the 6700k with a combo deal and one of the combos is the 6700k with 1 stick of 1x8. So I was thinking I would just buy this and pick up another 1x8 gb kit of the same memory but I wasn't sure if they would run dual channel.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104531&cm_re=hyperx_ddr4-_-20-104-531-_-Product < 2x8 kit
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104530&cm_re=hyperx_ddr4-_-20-104-530-_-Product < 1x8 kit
Thanks
It'll work
Yep, just try and buy two of the same kits
I know you said you would but eh
