Memory Question
Can you Mix Memory Speeds Such as 2 Sticks of 2133 and 2 of 1600
I believe NO. some one check me on this. is it possible to change the speeds to the same in the bios?
I think you can, the higher speed sticks will be downclocked to the same speed as the lower speed sticks. Thats the way I have mine set up. (Two sticks died and I got extras from a friend, I have 2 667 and 2 800)
My comp is old....
so basically there would be no point in using the old ram if i get new faster ram even though i would have more?
yeah you can only go as fast as your slowest memory.
