Kingston HyperX Beast 4 X 4gb 2400hz @ (Currently 647hz)
Corsair AX760 80Plus Platinum PSU
AMD R9 290
Samsung 840 Pro 256 SSD
WD Black 1TB
the issue is that i have tried setting up the timings on the motherboard manually but end up getting a failed boot. The exact Serial of the memory is KHX24C11T3K4/16X
i do believe there should be no issue with the compatibility but possibly something stupid that i have done in setting them up.
Any help will be appreciated
oh and there is a picture on my profile if you care to look.
That is a clean looking PC. How many other frequencys have you tried and at what timings? Subtimings might need to be raised a little as well, sometimes auto doesn't seem to do the job the higher you go.
