Hi! I’m about to do probably my last upgrade to my x299 system before it eventually is put into forced retirement. I got my hands on a i9-10940x for cheap and noticed the memory spec is DDR4-2933. I current have some ancient DDR4-2400 with xmp enabled. Would it be advisable to upgrade my memory with the new CPU or would I not see much performance difference keeping 64gb of 2400? I don’t really game at all and am mostly using 3D programs like Houdini and Blender.
On X299 i don’t really think that the performance gains,
from 2400mhz to 2933mhz memory would really justify the cost.
Because the performance gains will likely be marginal at best for certain workloads.
Honestly my recommendation would be to just stick with the memory you have right now.
And save money for a system upgrade in the near future.
