I used to have a mediawiki set up in Qnap media wiki etc…
Now i migrated to TrueNAS so I created a VM with Ubuntu 20~ and tried to run it there.
I’m very novice and I after lots of trying I could get it running, but the images is something that resists working.
- I can’t see any of the images I used to have. ( but if I access the folder using explorer or the file system there is no problem to see the image )
- I can’t upload new pictures.
- It won’t even load the favicon.
- downlading the images from the wiki pressing on the link will download a file but “corrupt” that I can’t open in any way.
The particularities of the setup would be that the var/www/html/mediawiki folder is a mount of a network location.
I tried to mount it with root permisions with the user permisions too… but no luck.
Thought it could be an Appache permisions
Any idea of what could be happening? I’m a bit out of ideas on what could I try next…
Thank you!
