Mechanical Mice for gaming?
Does anyone do gaming with a mechanical mouse? How does it do for gaming?
I would buy one if it was decently priced, but sadly it was a april fools joke
I remember taking the rubber ball out of computer mice and playing catch with them.
When I was little I could never figure out how to get them out
Mechanical has too much travel for use in mice.
I was kind of thinking that but can't there be a way to switch sensitivity up on software?
If they decreased the travel and decreased the sensitivity and you are basically back to Omron.
They typically had plastic rings that you could twist and remove to get to the ball... at least the one I remember using my first desktop with did.
Mine probably did, I was just too little to figure that out
I meant software not hardware
