Mechanical Keyboards
Can anyone recommend a decent mechanical keyboard for a good price? Any brand/make will do. Thanks!
you dont need a mechanical keyboard.
this one is great (though it is membrane). http://pcpartpicker.com/part/cooler-master-keyboard-sgb3012kkmf1us the reviews say it feels like mechanical, so i say go with this. its cheaper too.
What do you like in a keyboard? do you like a clicky sounding keys, easy to press with no click? Need to know what you like in one before we can really recomend one.
Clicky, tactile, firm. Similar to a BlackWidow, but a lot cheaper
I really wanted a mechanical keyboard but damn this deal is almost too good to pass on!
yeah check out the youtube reviews its a really good keyboard, and they say its like a mechanical keybard
they also say it clicky tactile and firm
What about headsets? Any recommendations?
oh wow ok with or without a mic? wired or no? price range?
here are some ideas of mine.
http://www.amazon.com/InnoGear%C2%AE-Cancelling-Surround-Headphones-Microphone/dp/B00U6XFBPU/ref=sr_1_23?s=electronics&ie=UTF8&qid=1430344287&sr=1-23&keywords=gaming+headsets
generally make sure the reviews are 4 stars or more, and check the specs.
If you want one without a mic...
They are great for the price if you want cheap with decent quality.
personally i use these http://www.yurbuds.com/en/behind-the-ear/47focus-100.html#/color-black with any good mic. you will get better sound if you go with headphones and a separate mic. i like ear buds but thats just my thing.
i use a corsair k70 for a keyboard, i'd say its worth a look
Anyone that says you don't need a mechanical keyboard just can't afford/justify spending the money. They are one of the best things you can buy to improve the user experience in my opinion and I think others would agree.
Decided to just go with the membrane and upgrade later to a mechanical. Thank you everyone for your help. I greatly appreciate it!
thats your opinion. it doesnt make your gaming any better
youre welcome! glad you like it. it comes in blue and red too
POK3R is great, High quality Aluminum case w/ stock PBT caps
