Mechanical Keyboards
Hey guys, I have a few questions about mechanical keyboards.
1) Why are they so expensive?! 100+ for a keyboard just seems a bit outrageous.
2) What does a mechanical provide (other than sound feedback) that a membrane doesn't?
3) If I were going to get a mechanical, what would be some respectable, yet inexpensive (or relatively inexpensive) ones that I should look for?
Thanks so much everyone!
1. They aren't, really. There are many sub $100 mechs, like the QFR, Rosewill RK series, and such. Also, Cherry MX switches have a 50 million click lifespan, compared to the 1 to 5 million on rubber domes. Even cheap $15 rubber domes are going to cost more to replace that often.
2. Not all mechs are clicky, or loud. They basically provide a better typing experience, with more balanced and consistent depression, which leads to lower strain and fatigue. They are more durable, with a much longer (10x, at least) lifespan per key. They come in a wide variety of weights, ranging from 35g to 80g+, making them much more likely to cater to your personal typing preference.
3. Depends on your budget; a solid number to work with would help. Do you want TK, TKL, 60%, compressed TK, etc.? Backlight, no backlight, media buttons, programmable, etc.?
I'd like the media buttons, but backlighting isn't necessary. Programmable buttons are not needed either. I'm not sure what you mean by TK, though... As for budget, 30-40 would be prime, 50 would be my max. Sorry if that's really low.
Ehh, you really can't go that low for a new mech, especially with those features.
TK means numpad; more correctly, it stands for tenkey. TKL means tenkeyless, or no numpad.
This is the cheapest mech I would recommend is the QFR and Rosewill RK9000 series; $60 to $70 for a very nice, solid board.
