Mechanical keyboard suitable for me
The title may be confusing, but I'm looking for a suitable mechanical keyboard for myself, but so far, I haven't found one that fits me.
What I'm looking for, is a simple mechanical keyboard for gaming, I mainly play FPS's, so I don't need useless stuff like macro- and media keys.
I think I prefer Cherry MX Blue's the most.
Here comes the tricky part, the layout, I want something with short left shift, so a keyboard with a swedish layout:
http://www.goodtyping.com/teclatFINok.png
SteelSeries 6Gv2 is quite close to what I'm looking for, but enter is kinda messed up.
So my question is... Is there a keyboard in existant that will fit me?
Corsair K70:
Swedish layout and a small shift key. And the enter key is not fucked up lol.
Not really fond of the design of that keyboard(I know, i'm picky).
I don't blame you. I think the Mx blue variant has a horrible metallic look. They are releasing an RGB model, like the one above, with customisable backlighting. Probably the best you're gonna get.
Hmm.. Might of found the perfect keyboard for me:
 QPAD MK-50 Pro Gaming Mechanical Keyboard
I'm sure it is a good keyboard.
Take a look at Ducky DK9008 Shine 3; I have the Shine 2 variant, its plain and simple design, but its one of my favorite brands of mechanical keyboards out there.
Hmm, I would try look at the Cooler Master CM Storm Quickfire TK.  Its nice and simple, come with a key removal tool and has a configurable blue backlight.
Check out Filco, they have pretty much every layout you'd want, and their build quality is second to none.
If that doesn't flow with you, then look at DasKeyboards, CM, and Ducky.
Also take a look at WASD, I don't know if their build quality is prime like the others, but they are fully customizable and have all layouts that are within 104/87-key and 105/88-key layouts.
The qpad keyboard is out of stock everywhere with swe layout and blue switches....
Out of all the suggested one's, all of them seem to have freaky enter.
As I said before, I'm really picky when it comes to a keyboard layout.
Looking at the picture, that is a UK layout but with the keycaps changed for relevant Swedish symbols. I OS handles what key does what does it not? If that is the case braien334 could buy any MX blue UK layout keyboard and just get some Swedish keycaps. They have to easier to come across than an entire keyboard with all the requirements.
Here is a Filco Ninja MX Blue Swedish layout, pretty sure the ninja will annoy: http://www.keyboardco.com/keyboard/swedish-finnish-filco-ninja-majestouch-2-nkr-click-action-keyboard.asp
And a non Ninja Filco with blue switches and Swedish layout in stock to boot: http://www.keyboardco.com/keyboard/swedish-finnish-filco-majestouch-2-nkr-click-action-keyboard.asp
Close ups for scrutiny: http://www.keyboardco.com/keyboard/swedish-finnish-filco-majestouch-2-nkr-click-action-keyboard-image.asp
If you right click and click open image in new tab, it will give a clear view. The layout is exactly the same as the specified layout, but it isn't a preferable keyboard.
I did, that's what I was looking at, but I was looking at my keyboard at the same time and except for the alternate Swedish key markings it is identical to the standard UK layout.
Either way there is at least one keyboard in there now with the exact spec and a generic look so it should suit. Hopefully.
