Mechanical keyboard Mx Green Switches
Sup guys, I've been looking (eye-shopping) for a mechanical keyboard with cherry mx GREEN Switches..
What mechanical keyboard are your favorite?
Keyboards with mx green or mx green-like switches alike! :P
Have you heard of google? It's a search engine that you copy and paste your topic into and it gives you results. It's like magic!
On a side note, ducky makes good keyboards,so does CM.
He came here for recommendations, not to find MX green keyboards. You could still ask google but there's no harm in asking here. Stahp turning people away @VXAce myrerherhhh. It's not like he's asking what distro he should go with or the like...
Anyway, WASDKeyboards do some in MX greens and they supposedly make decent keyboards.
I've been useing a cooler master keyboard its been great
My intention was to get him to look up the keyboards, there are very few MX Green keyboards out there.
I like this one
https://codekeyboards.com/
But it was too expensive so I ordered this one with blues though they do offer a green version (With black not white)
es-87
I use a WASD code with Greens and I love it. The only reasons I can think of as to why you may not like it is if you don't want a white backlight or the price.
Waow.. gee thanks!
That's amazing!
How can it do that.. Damn.. I will never need to ask anyone, anything ever again! :D
But I can't see how it would say what keyboard you like the best?
Does it ask you for me? :P HOW CLEVER! :P
Waow.. is that a CODE!
Can you get them with a white backplate or is that a custom one?
And that is actually what makes me come and ask for recommendations.. You might know something I don't :P
It is a KUL ES-87 which is the next best thing at a much lower price.
http://www.keyeduplabs.com/es-87.html
They come in a range of switches including green but when it comes to the white frame, all but the green have that option stock.
https://elitekeyboards.com/products.php?sub=keyed_up_labs,tenkeyless
However you can find a replacement white frame if you want a green es-87 with the frame.
https://elitekeyboards.com/products.php?sub=access,housings
Also comes with red and blue options.
Only flaw with this keyboard is the key caps are some of the worst key caps put on an mx keyboard. ABS, will wear out quickly. But thats another $40 to replace them with higher quality caps down the track if that's what you want.
Note this keyboard does not have a back light but that brings the price down on a very professional looking keyboard.
Not sure about green switches. I have owned a Dukcy, Mionix & Filco. The Ducky was good the others so so after the shine wore off. Currently I have a CM Storm and Func both of these are great and I have been using for months.
I have the cm storm stealth in mx green. Really solid build quality.
Also have a kb paradise 60% in green love that one too has green and blue led back light. Love 60% my self but you might not want one.
Those keys seem freakishly big but they're just normal size yeah?
yea the keyboards just small.
No shit? XD
Nice keyboard there!
Do they come un-tenkeyless?
:P
Im having a hard time imagining not to have the numberpad..
no but you can get a add on number pad. I prefer to set it to the right of the mouse because i only use it for IP addresses.
That's a good idea!
Think I'm going to look into numpads with cherry switches.. if such a thing exists xD
They do but you have to keep an eye out for sale to get one at a good price.
http://www.geekkeys.com/leopold-fc210tp-21-key-numpad-light-grey/
massdrop has them sometimes too.
Otherwise you can do everything on them that you would a normal keyboard due to the function layers. If you want a lot of layers look at the poker3. otherwise there is the pure pro, kbparadise v60, and a couple smaller custom projects.
Right now i have a problem where i have mechanical keyboards like women have shoes:)
