I've been looking to buy a mechanical keyboard, and within my budget I have nailed it down to two selections, and have decided on Red or Brown for the MX Switch. I do a mix of gaming and typing (work) so these two look the best for me.
I'm looking at either the CM Storm TK with Browns, or the Func KB-460 with Reds, both are £65 - I'm from the UK.
I know about all the different switches, and their respective differences, however even despite this I still cannot make a choice because of some concerns regarding Browns and Reds.
For Browns - I am aware they are quieter than Blues, but in general are they fairly quiet - coming from rubber domes, I don't want to make a racket. Also how are Browns for games which are WASD dominant (e.g. First Person games - like FPS', Skyrim etc.), I've heard some negative things regarding the tactile bump while sliding your fingers over.
For Reds - how are they for typing - I already know they are light, and great for gaming (e.g. double tapping) - but are they decent for typing, even without a tactile bump?
I know about the switch tester kits you can buy, which I will consider also if I can't come to a decision, and I have looked at the respective guides on mechanical switches too, as I iterated above.
Any feedback regarding this - to a user coming from rubber domes, and having never tried a mechanical keyboard before, would be very welcome, thanks.
If you're planning to buy a CM keyboard, you can purchase a mech key tester from CM and use it to get discount from your selected keyboard.
http://www.cmstore.eu/cm-storm/keyboards/mechanical-key-switch-tester/
It says the expected release date is not until the 6th though - I'm looking to order within a few days ideally, but thanks I might consider waiting if so - any feedback regarding my concerns?
Furthermore, having just checked - the EU store appears only to have the TK with Browns in the US layout as an option to purchase unless I'm wrong, that's annoying.
Since I'm from the UK - I'm looking at the UK format with large enter and £ sign.
Anyways, anybody have any user experience feedback?
I have the CM Storm Quickfire TK with blue switches.
It's the first mechanical keyboard I have owned or used and I absolutely love it.
I see you're from the UK. I'm from Ireland and bought my keyboard off OverclockersUK, they're a good place to buy from, I got my keyboard shipped to Ireland in 2 days. Here's the link to the board I got :http://www.overclockers.co.uk/showproduct.php?prodid=KB-015-CM&groupid=702&catid=2705&subcat=2707
I'd definitely recommend the CM Storm TK option you mentioned. I also love the fact that the keys such as home, delete etc. are built into the keypad, so you can have the functionality of a number pad in a 10 keyless form keyboard with the touch of a button.
Also, the steel backplates are colour matched with the LED lights in your keyboard, which adds alot to the effect of the LED lights. Overall the keyboard has a very stirdy and feels extremely well built, I don't think you'd regret buying it!
Thanks - although I am already aware of the quality of either board, my issue is more of a switch problem, as stated I simply can't choose.
Regarding the TK though - many of the UK format boards have the accented vowels on the keycaps for some reason - does yours have this, and if so does it still just type out normal vowels?
I'm aware of OCUK - I've bought several components from them in the past, but I'll be buying the TK with Browns from Ebuyer.com since it is £65 and free delivery.
Thanks for the feedback.
