Mechanical Keyboard Corner
That post lit a fire under me to replace my WASD Code.
Glad I could help. :stuck_out_tongue:
I genuinely think this is a top-tier keyboard.
Hoping to be getting an ALT for Christmas.
If its anything like the CTRL, you’ll really enjoy it.
Now that my PC builds are done, back to working on my Heavy-6 build.
Any good looking, not too expensive mini-usb cables you guys would recommend for my Leopold?
The stock one is too simple.
I went for a paracord braided kit one in the end that I made myself, that was a decent price thought I cqnr remember what that price was now.
I do need a new one though as my soldering was crap and it broke in the end, totally my fault, that cable was good materials just my bad workmanship. There are ones that don’t need soldering now that just clip together and crimp the wires in.
Man, that would be great for me, i have a hard time trying to solder anything, my hands are way too shaky.
I tried contacting a local guy that makes paracord mouse cables to make a mini-b cable for me but he told me its too hard for him to make.
MiniUSB as in Type A on one end, Mini-B on the other?
I like the Delock transparent ones:
Amazon com $7.23
Yep, exactly that.
That cables looks nice too!
Just need to get some genuine stabs and maybe some lube.
Brought the nicer keyboard to work, I never realized how much more I like tactile switches for typing until now.
I also didn’t realize I soldered the three bottom left switches one position too far to the right until I put the keycaps on. Whoops.
How are coworkers handling the noise?
This keyboard is quieter than the previous one for whatever reason. Neither should be loud since the previous one had linear switches and this one tactile, but the previous one had much more pronounced plastic on plastic sound. Aside from the stabilizers on this one it’s about as loud as the OEM rubber dome keyboard.
I don’t understand, could you explain the problem?
Being a custom keyboard there are multiple spots to solder some of the switches. I messed up and soldered three switches in the wrong spots, so now they don’t line up properly.
Note the overlap of the sushi key and space bar:
Now I get it, thank you.
I hope you resolder them.
Did anyone notice? Unicomp announced a tenkeyless model:
So since the lube was botched on the last run of holy pandas, I am going to disassemble and clean them. This presents the opportunity of trying different springs.
Can anyone give me the breakdown of the options (other than weighting, which is obvious). What are the pros/cons of the different materials. For instance, I can’t imagine what the benefit of gold plating is
