Went to Goodwill today.
Pretty good day.
Are those alps switches?
SMK gen 2 inverse cross mount whites.
Thank you!
In theory the Unicomp keycaps will fit a vintage Model M, correct? The Model M at work is missing a couple caps.
Also, anyone know how durable the plastic case is? It looks like it has tar buildup from somebody smoking over it, so it needs a very strong bath.
I have both model Mās from IBM and UNICOMP and yes they are interchangable.
Different models though might be 1-2 piece keycaps.
1987 terminal keyboard and a 2017 Unicomp version.
Except for buttons like enter and shift as the older IBMās use wire Stabilizers and the UniComp uses rod stabilizers.
Isopropyl alcohol will clean it up nicely or soap and water.
Awesome, dziÄkujÄ ci!
Itās missing the tab keycap and a couple others are mislabeled or blank, so Unicomp will save me some struggle.
Assuming the keyboard can be taken apart without too much fuss Iām thinking Iāll give it a bath and a good scrub with a couple mixtures.
For US$130, Leopold FC900R, Matias Quiet Pro or something else entirely?
Hey, thought Iād share my recent find at the local dump/recycling center.
Norwegian IBM Model M, 1986 production. Iām pretty sure itās pre-PS/2.
I canāt really find any information on this model, as itās both missing the model number.
But the internal parts are also impossible to get any info on, 0 hits on google.
I have already ordered the missing keycaps from unicomp.
Otherwise all the keys work flawlessly, and the keyboard has never had any liquid inside it.
Probably uses an SDL connection, you can get SDL / PS2 or SDL / Soarerās usb converter.
Oh, Iām already using it on a PS/2 to USB converter and it works just fine.
It came with the connector in the keyboard with just a cut cable, just opened it up and soldered a normal PS/2 cable onto it.
Mostly for testing, new cable is on the way.
The lack of lock lights makes me think itās an ISO 102 key terminal keyboard, not like that observation is really helpful though.
If it were a terminal keyboard, there would be a non-standardised numpad.
IBM Model M Terminal keyboards range from 84-122 keys and a few specialized industrial keyboards have over 122 keys.
There are those variants too.
What are you looking for? Iām sure somebody in here can help
You know what, thatās an awesome idea! Thanks!
Okay, here is my conundrum:
Up until now I have been using cheap Logitech keyboards and my current one is slowly dying. I have thought about mechanical keyboards for a while now but if I pay that much money for a keyboard it has to be pretty much perfect and I have not found it yet. If I keep using cheap keyboards I at least have saved some money and know why itās far from perfect.
I am not sure if what I am looking for exists or if I could afford it but this would be a rough description of my dream keyboard:
In case I happen to have too much time on my hands in the future I am building it on my own. This is going to be an interesting blog post.
