Huh, shit one I have had one not arrive, out of like 30. Everything else has been fine.
I know itās just my luck. I have friends, who run entire stores with products from AEā¦ And here I am, arguing with a seller āgo to the post office, itās thereā, āIāve been there, itās notā, etcā¦
Anyways, I will try the site one last timeā¦
I really want to get rid of the click from plastic to plastic contactā¦
O-rings will only get rid of one of the clicks. the down click if you bottom out the press. The up click will still be there.
And it also wonāt dampen the click from internals of the switch, whether that is on tactile or clicky switches.
It will make linear switches silent though.
Not completely, still that up click of the slider hitting the inside of the switch. Sauce: Reds with o-rings.
Not sure if MX blacks are different but my WYSE with MX blacks would be silent if I had o rings on it.
Maybe is because they are vintage ones?
They all work the same. It definitely makes them a lot quieter as the spring is not super hard and wont slam the slider up hard, but it will still hit the top of the switch, Plastic on Plastic will still click some amount.
This is why they also have the ānewā MX silent switches, they have a little bit of rubber on the top of the sliders to cushion the up click.
Hmm. Dampened alps seem like a much better way to go in that case but thatās just my 2 cents lol. Then again modern dampened alps arent dampened as well as the older ones are soā¦ Yeah.
Yup totally agree, but than again the ALPS would have been made with that in mind from the start. A lot of people like the MX for the click clack, pretty defining feature.
I know thatā¦ Itās just that Iām a silence freak. I set my system for <20dBa operation noise, so I can do whatever I want even during the night and will not be bothered by fan noise. And typing isā¦ Wellā¦ I want it to be quieterā¦ As quiet as possible.
But the MX blue click is so harsh lol.
Its not that satisfying compared to IBM, or even Gateron (let alone Alps).
Then again I dont suppose many people even know anything other than Cherry MX exist so theres also that.
Hmm. Your best bet would probably be MX silent (or the Kailh/Gateron equivalents)
dampened alps.
O rings will help your current keyboard but probably wont make it completely silent.
Not sure if theres any super quiet switches out there beyond that.
I know of super smooth switches but thats only semi related.
I knowā¦ The reds I have are quite good in any aspect. Itās just the click. I donāt think I can make them completely silent, but I will do what I can to make them quieter than they already are.
Canāt really master touch typing, though I tryā¦
Anyways I will update in a couple months probably that the Rings are killing my backlighting or they didnāt arrive or somethingā¦
Well they know ācheap Chinese knock offsā, no matter they are basically the same switchesā¦
This.
They are physically nearly identical and yet people dont like them. I dont get it, they are usually a lot cheaper and just as good lol.
Sometimes a lot better, for example Kailhās new switches like the Box ones and double click ones. Among others.
Oh well.
My Thor 300ā¦ A 35ā¬ keyboard with like 10 different light modes, a couple custom light modes and Nkey roll over and what notā¦ Some 100$ cherry keyboards donāt have that many extrasā¦
PS: Iām in the process of filming some stuff and making a video about itā¦
Get them clear ones.
I took a chance on the Fnatic Rush Silent keyboard (Cherry MX Silent Red) and was not disappointed. It beats my first(and the first ever) keyboard with the same switches, the Corsair Strafe RGB on all accounts except the RGB which I never wanted. Even the build quality of this keyboard is better, at around half the price.
They key caps are quite slippery but that hasnāt been a problem for my typing at least. On the flip side it makes them easy to clean with a quick wipe which I appreciate. The soft touch coating on the keyboard body also is not overly grippy, something that made an older keyboard I had a bit tricker to wipe off.
I had to order if from the Fnatic store since nobody carried it here in northern Europe, but apart from the one week delivery time (partly through Amazon) that was no problem. ā¬10 extra for this new variant with the āSilentā is a no-brainer option really. I guess I would have paid a little extra for something like a removable USB cord as well, but Iām nitpicking.
What a strange keyboard. Need to clean the thing but has 8 (so far) different switch models on it in two colors.
@Zibob this is definitely one of my more intriguing finds. Not unpleasant to type on but I need to clean it more and stuff before I do more in depth analysis.
One odd thing is that it hasā¦ ABS double shots? Didnāt know that was a thing but apperently it is lol.
Very common. All of GMK are this. Most of SPs stuff too. Like all the SA caps, except the dye sub PBT ice caps.
PBT double shot is technically harder due to warping, but mostly not an issue once you have that down, but over all dye sub is easier, cheaper and more variations easier. The only downside is only being able to have legends in darker colours than the caps, with double shot you can do lighter legends.
The best is PBT double shot with Dye sub, sub legends.
It is usually the cheaper Chinese stuff that is double shot PBT oddly. Like the Tai Hao caps and all those PBT POM shine through double shots.
