That's the thing, I kinda always need it since I'm in Excel or otherwise punching in numbers quite frequently. I could probably get away without the F-keys, but not a numberpad.
I was initially thinking of trying a TKL, but the whole numberpad thing again.
I did see this layout on the Red Scarf II on Massdrop and I think it's just about perfect. It's $138 for just the PCB and case though
I have a compact 1800 and it is amazing, same as above but with a function row too, a full layout but only 1.5 keys wider than a TKL, was not cheap though, similar idea to the RedScarf.
80 dollars US ish. 96 layout, milled acrylic case, reprogrammable PCB. Apparently the only bad 0art is the plate fr the switches is not great quality. This is what the group buy was to solve.
Edit: @w.meri it came back get on this shit. A more basic version case wise but the full 96 layout like the RedScarf. Go! Go! Go!
The green backlit one? Looks like a Razr keyboard, you can see their crappy font that many keys share the same exact symbol in pairs. EDIT 2: Looking for keyboards with those slices in the front.
Okay found it!
Sorry for the misinformation right off the bat. I was considering that one over a TKL since its about as small but includes a 10 Key. Edited link since it led to the brown Pro M one which is not available. Seems that its only available in Reds from Amazon. Perhaps on Newegg there is the Blue and Brown switch versions.
EDIT3: Brown and Reds available on Newegg, blue says pre-release.
What @Walter said but also Redragon Keyboards on Amazon are quite good for the price, if you like Blue switches. They run from $30-60 typically. I have one and its quite nice, (Redragon K552)
I saw this one for the price and bought it, its a damn steal.
Pretty much blue switches, it is white backlit but that is fine since it goes well with my build. A few lighting modes and a couple programmable key lighting layouts.
