Mayhem's Aurora In My Rig
I call my rig Radioactive, Coolant is from Mayhem
http://www.youtube.com/watch?v=dFaNcmLbFSc&feature=share&list=UUASoOpkaq_tQypHWs_RoPBw
WOW THAT LOOKS SICK!!
Does it clog any of the water cooling loop?
If that stuff ends up clogging then let us know, because Epic PC Cases used the blue stuff in one of his builds and it completely separated, fell apart, and clogged his loop.
Well it can, Its very simmilar to oil and water it seperates. You have to have a beefy pump and high flow waterblocks or else the pearl will fall out and lay in the bottom of the tubes. But using a fast pump and a cylinder res it keeps it mixed together so it doesnt seperate. EYE CANDY!
Urk, I think i sneezed that....
Here it is starting up from being shut down overnight ( Cant sleep with led fans ) The liquid had fully seperated.
http://www.youtube.com/watch?v=UsANHENSYSk&feature=plcp
Yeah it looks really cool, but I think I'm just going to use distilled water in my loop when I finally buy it and put it together. I always hear horror stories when it comes to dye.
That looks sick, I really have to swap out my H40 soon,
You can get clear fluid that is non conductive, Fluid Xp makes some as well as feser. I agree with no dyes, i had some deep blue feser in before this and it stained everything blue lol
Well yeah, but this mayhems coolant obviously has dye in it, lol. And I'd much rather just used distilled water than clear fluid, lol. I don't see the point in getting clear coolant when you could just use water.
Im not certain how bad the mayhems stuff will be in a few months im sure it will be all nasty. Reason to get  fluid instead of Distilled is becuase it has biocides and anti-corrosion additives in it. Some of them even have anti-freeze
Yeah, but you can just add that to the distilled water separately and it would be much, much cheaper than buying coolant.
True, Woot i got my t-balancer in today, undervolting fans FTW! Now just waiting on some UV and green cold cathodes and 2 more gelid fans
Well its about 11 months and i noticed my temps going up. This is what i found. Smelly TOO!
