Im on a $700 dollar budget and i was looking for someone to reccomend a build to me. Im gonna be using it as a gaming pc btw.
Corsair Vengeance 8 GB ( 2 x 4 GB ) DDR3 1600 MHz
Corsair Builder Series CX 600 Watt ATX/EPS 80 PLUS
Gigabyte AMD Radeon HD 7850 1GB
Hey, thanks a lot this is perfect. just need a good monitor now
Glad to help, good luck building.
For 40 bucks more you can get a 7870 and 1TB of Storage:
http://pcpartpicker.com/p/GRq3
But if you are limited to $700 than the build above will be great.
Better priced motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131873
Better priced PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
Better priced chassis:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129187
Better GPU with money saved:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202006
that GPU is a little too pricy for me but thanks for the other reccomendations man
Will this fit your budget with the extra saved on the parts above?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161404
Well i also need to pay for a monitor and an op system.. You've helped a lot though thx
Can anyone improve on this? (price wise)
EDIT: Made case and MoBo compatible http://pcpartpicker.com/p/GS6r
Even though you have a smaller resolution monitor in there of only 1366x768, i think that 7850 is a perfect match, and Vram will not an issue for you for a long while...
If i found a 1920x1080 monitor for near that price, i would say it will be lower quality, and will waste the potential of that GPU...
That monitor and GPU is a nice combo imo :)
If you want to shave off a good chunk of cash, download Windows 7 by other means...... but do remember, there is always a risk with this method, and i do not support piracy in any way, but it is a suggestion (i have been there when money is very tight).
http://pcpartpicker.com/parts/monitor/#r=192001080 which monitor did u have in mind?
You don't need to pay for an operating system. All versions of windows 7 are readily available for download for free as an iso file.(not just on torrents) Then just burn it on a usb drive and install it that way. And there are safe methods of activateing it without having a valid key.
Thank you!
http://pcpartpicker.com/p/GSmL
got it down to $790. any way i could maybe shave down the cost on the video card for about the same performance? also would i need a sound card?
No need for a sound card.
Performance near the 7850? that would be a GTX 570/480 or Radeon 6970/6950 which either cost more, or will not run on that PSU..
ok thanks a lot. Will there be any need for me to purchase cords for the pc?
http://pcpartpicker.com/p/GSQc
Thats the best i could squeez out of your budget, heres my breakdown of what i changed
Changed the Vid card to a GTX 660 because it will be faster than a 7850 1GB
Choose the Gaia CPU cooler because it is about as good as a Hyper 212 EVO at a lower price
Had to switch out the ram because either cooler didnt have enough clearence (the kingston is also cheaper)
Changed the case to a sturdier more reliable one with more options than the other one
Put in a Higher Quality PSU compared to that Antec because the more reliable/effecient the PSU the better.
And finally i got you a 22" LG monitor because its better than the Acer (dynamic contrast and colours) and its slightly bigger.
