Recently I turned on my machine, fx 8320 OC to 4.6GHz, with 2 x GTX 660 in sli. Now for whatever reason, even in SLI, I get 1/2 the FPS as a week ago, and the same FPS as when I use just one card. Also my CPU usage even under prime 95 and anything else is pinned at 47% no higher; I get 100% on two cores, and about 20% on the other six. I have tried different bios settings, even though the OC was stable, and now i can only acheive 100% CPU usage at 1.8GHz or less... and I still have no idea what is up with my GPU's :/
I've done a virus scan aswell, Kaspersky, and it came back clean as far as I know..
Temps are fine, all around: stress temps are between 48-60 for the GPUS and HW monitor reads 37-39 on the CPU when it's stressed, mind you again it is only running at 47% for some reason
Temps are fine, all around: stress temps are between 48-60 for the GPUS and HW monitor reads 37-39 on the CPU when it's stressed, mind you again it is only running at 47% for some reason. MB temp at NB is about 40
could be some recent windows update that cause it. Do you keep weekly system restore points? I would suggest doing a system restore back to before the problem started.
There may be a problem with the software installation you are using to stress test. try downloading other stress test software and see if thats able to get up to 100% on all cores. Apart from that alli can suggest is resetting the CMOS on the mobo and see if that helps.
I will try the CMOS reset.. I have tried, prime 95, OCCT, and amd's over drive stuff none of then can push the cores past C1 100% C2 100% C3 22% C4 22% C5 22% C6 22% C7 22% C8 22% utilization. I have used Ugine valley bench mark and compared them to my non-sli scores and and my previous scores (like 40 of them) and the scores now are about 30-40% less than my previous scores.
Aida seems to be able to push the CPU to 100% at 4.6GHz, which is great! .. My GPU's even performed at regular performance for one run of heaven benchmark! Then it never performed well again (temps at 61 deg on hottest GPU)... really not sure whats up. I have swapped and reseated the GPUS and tried each by them selves. Nothing useful. Any other suggestions!? Again, much appreciated!
