Hi, I'm looking for a good quality mATX motherboard(1155) for a build. Not really many requirements except it needs to handle 1600mhz ram. I found a board on amazon that I will probably buy if I cant find any other good choices. I will take any suggestions and thoughts on the one i found, thanks.
as far as i know that msi board is fine, also i never read bad revieuws of the Asrock Z77 Extreme 4M
Okay thanks, i will probably just go with the msi board then.
I heard some people saying that the newer MSI's have been running way hot, i don't know much about it but it may be worth a Google search...
