While I was optimizing the cooling in my computer case via the BIOS, I came across an option to specify the fan speed on each fan header on my motherboard (Gigabyte GA-Z97X-UD3H). It lets me choose between "normal", "silent", "full speed" and "manual". When I pick "manual", I can access a new field below where I assume that I can pick the fan curve.
The following options are possible from the drop-down menu:
- PWM 0.75/°C
- PWM 1.00/°C
- PWM 1.25/°C
- PWM 1.50/°C
- PWM 1.75/°C
- PWM 2.00/°C
- PWM 2.25/°C
- PWM 2.50/°C
Now what do these values mean? I checked my motherboard's manual [PDF], but it doesn't say much about this. The only thing they mention is this:
I assume that it controls the duty cycle of the PWM controller and I am guessing that it might be percent per degree Celsius. But what does that even mean?
