Title kinda covers it - going to install one or the other. Anyone have thoughts on this? Stability?
Use case is office work and gaming
Hardware is 3800X, X570 master, GTX 1080
Manjaro is definitely great if you wanna game on it.
I have never tested Tumbleweed unfortunately.
Theyâre both fine distros, but they feel different.
OpenSuseâs claim to fame is Yast. You either love it or hate it.
Manjaroâs got package availabilty, and is much loved by people who know what GPU they have.
I mean rolling is rolling. You want a master level build system or one click install
I am currently using both.
Both are very good, different but good.
You canât go wrong with either.
I once heard non-Debian based distros didnât fare too well [edit] for gaming[/edit] because of compatibility and stuff.
For gaming wouldnât a *buntu be better?
Manjaro is actually great for gaming. Between Kubuntu and Manjaro KDE there is a minimal performance advantage on the Manjaro side but overall both are great. Iâve played Steam stuff on Proton and WoW over Lutris on both systems.
Iâve used both Tumbleweed and Manjaro and gamed on both. I personally liked Tumbleweed better, but you canât go wrong with either. That said, Iâve been having more and more issues with OpenSUSE lately and just removed it from the last system I had running it. And installed the best distro instead.
OpenSuse is bloated; but that means itâs easier to get things such as KVM upâŚ
Manjaro is generally running beta software / newest; OpenSuse is using slightly older; this can reduce compatibility with new hardware but will be more stableâŚ
Oh? And what is this fabled âbestâ distro?
Oh no, donât start it please. This could turn into a shitstorm very fast.
haha
Thereâll always be the âmy distro is better than yoursâ and âyour distro sucksâ
clearly hes talking about fedora gentoo. the one true distro of big brained linux users.
Damn - i had my money on either Arch or Linux from scratch.
Sir, if you could please refrain from using curse words here, this is a christian minecraft server.
I once heard non-Debian based distros didnât fare too well for gaming
The package manager itself doesnât matter all that much, and thatâs the only thing that makes Ubuntu âDebian-basedâ these days. Packages are not interchangable, and the release cadence is different.
That release cadence is the single biggest factor for non-potato Linux gamers. Older hardware is generally fine, but current gen hardware needs a rolling release in order to get new features supported at every level of the graphics stack.
Ubuntu has no rolling release. Ensuring your entire graphics stack is up to date on Ubuntu requires you to upgrade several major system components using third-party repositories which is generally regarded as a Bad Ideaâ˘.
Itâs absolutely possible to do on Ubuntu, but itâs one of the worst experiences for gamers, IMO. You have to fight with core elements of the systemâs design in order to do it.
I have been running Manjaro for the past 6 months on my main system.
Itâs been realy good, no problems at all, and pamac makes working with the AUR and updated package builds extremly simple.
I havenât had a single issue related to updates or instability, and being based on Arch, if you are looking for a piece of software, chances are someone already made it available in the AUR if it is not in the software repos.
I would recommend Manjaro to anyone looking for a good rolling release distro at this point.
gentoo
Yeah when steam came out. Doesnât matter anymore.
