Hi all,
I’m not able to get a wifi connection on my Dell G3 running Manjaro on kernel 5.4.2.
I’m just getting “not connected” in the taskbar’s network manager (running KDE).
Here’s some info:
lspci | grep Network
00:14.3 Network controller: Intel Corporation Wireless-AC 9560 [Jefferson Peak] (rev 10)
uname -r
5.3.15-1-MANJARO
ip link show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp3s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
link/ether d8:d0:90:42:d7:27 brd ff:ff:ff:ff:ff:ff
3: wlo1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DORMANT group default qlen 1000
link/ether d0:ab:d5:38:8e:20 brd ff:ff:ff:ff:ff:ff
uname -r
5.4.2-1-MANJARO
ip link show
After toggling wifi off and on in the taskbar’s network manager I get
ip link show
174: wlo1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether ea:ae:55:b5:78:49 brd ff:ff:ff:ff:ff:ff
ip link set wlo1 up
RTNETLINK answers: Operation not permitted
sudo ip link set wlo1 up
RTNETLINK answers: Input/output error
I’m quite out of ideas and any input would be great.
Any errors in dmesg?
does manjaro have an LTS kernel package? You could just fall back, might be easier.
Kernel 5.4.2 was only released on Manjaro testing branch 3 days ago
suggest stay on 5.3 kernel on stable branch until 5.4 kernel released there too
I didn’t check dmesg…
Anyway, I returned to the last stable version (5.3.15) and have the LTS version (4.19.x) installed.
Ahh I’m running testing aka arch stable.
Still this will pose an issue in the future, right?
gothicVI:
Well, that’s where you’re going to find your kernel errors.
Well, it seems like manjaro testing is not equivalent to arch stable, so I’d imagine it will pose an issue in the future.
Since the kernel is now listed as LTS I’ve tried again and here’s the dmesg message:
[ 192.384655] iwlwifi 0000:00:14.3: Firmware not running - cannot dump error
[ 192.776524] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 192.776890] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 192.776895] iwlwifi 0000:00:14.3: Status: 0x00000050, count: 6
[ 192.776897] iwlwifi 0000:00:14.3: Loaded firmware version: 46.6bf1df06.0
[ 192.776901] iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 192.776904] iwlwifi 0000:00:14.3: 0x00A022F1 | trm_hw_status0
[ 192.776906] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 192.776909] iwlwifi 0000:00:14.3: 0x004882DA | branchlink2
[ 192.776911] iwlwifi 0000:00:14.3: 0x0047932A | interruptlink1
[ 192.776914] iwlwifi 0000:00:14.3: 0x0000B072 | interruptlink2
[ 192.776916] iwlwifi 0000:00:14.3: 0x0001A83E | data1
[ 192.776918] iwlwifi 0000:00:14.3: 0x00001000 | data2
[ 192.776921] iwlwifi 0000:00:14.3: 0xF0000008 | data3
[ 192.776923] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 192.776926] iwlwifi 0000:00:14.3: 0x00039564 | tsf low
[ 192.776928] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 192.776931] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 192.776933] iwlwifi 0000:00:14.3: 0x00039564 | time gp2
[ 192.776935] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 192.776938] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 192.776940] iwlwifi 0000:00:14.3: 0x6BF1DF06 | uCode version minor
[ 192.776943] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 192.776945] iwlwifi 0000:00:14.3: 0x18C89008 | board version
[ 192.776948] iwlwifi 0000:00:14.3: 0x001D0177 | hcmd
[ 192.776950] iwlwifi 0000:00:14.3: 0x00122080 | isr0
[ 192.776952] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 192.776955] iwlwifi 0000:00:14.3: 0x08001802 | isr2
[ 192.776957] iwlwifi 0000:00:14.3: 0x404001C0 | isr3
[ 192.776959] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 192.776962] iwlwifi 0000:00:14.3: 0x001D0177 | last cmd Id
[ 192.776964] iwlwifi 0000:00:14.3: 0x0001A83E | wait_event
[ 192.776967] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 192.776969] iwlwifi 0000:00:14.3: 0x00000820 | l2p_duration
[ 192.776971] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 192.776974] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 192.776976] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 192.776979] iwlwifi 0000:00:14.3: 0x08081425 | timestamp
[ 192.776981] iwlwifi 0000:00:14.3: 0x0000183C | flow_handler
[ 192.777129] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 192.777132] iwlwifi 0000:00:14.3: Status: 0x00000050, count: 7
[ 192.777134] iwlwifi 0000:00:14.3: 0x20000034 | NMI_INTERRUPT_WDG
[ 192.777137] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 192.777139] iwlwifi 0000:00:14.3: 0xC008885E | umac branchlink2
[ 192.777142] iwlwifi 0000:00:14.3: 0x80454D04 | umac interruptlink1
[ 192.777144] iwlwifi 0000:00:14.3: 0xC00842AC | umac interruptlink2
[ 192.777147] iwlwifi 0000:00:14.3: 0x00000400 | umac data1
[ 192.777149] iwlwifi 0000:00:14.3: 0xC00842AC | umac data2
[ 192.777151] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 192.777153] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 192.777156] iwlwifi 0000:00:14.3: 0x6BF1DF06 | umac minor
[ 192.777158] iwlwifi 0000:00:14.3: 0x0003954C | frame pointer
[ 192.777160] iwlwifi 0000:00:14.3: 0xC0886B5C | stack pointer
[ 192.777163] iwlwifi 0000:00:14.3: 0x001E010C | last host cmd
[ 192.777165] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 192.777184] iwlwifi 0000:00:14.3: Fseq Registers:
[ 192.777194] iwlwifi 0000:00:14.3: 0xD9691F0C | FSEQ_ERROR_CODE
[ 192.777204] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 192.777214] iwlwifi 0000:00:14.3: 0x7F5B52FF | FSEQ_CNVIO_INIT_VERSION
[ 192.777224] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 192.777234] iwlwifi 0000:00:14.3: 0x56769A21 | FSEQ_TOP_CONTENT_VERSION
[ 192.777244] iwlwifi 0000:00:14.3: 0x22DD5979 | FSEQ_ALIVE_TOKEN
[ 192.777253] iwlwifi 0000:00:14.3: 0xAF64419A | FSEQ_CNVI_ID
[ 192.777263] iwlwifi 0000:00:14.3: 0xCF84088E | FSEQ_CNVR_ID
[ 192.777273] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 192.777285] iwlwifi 0000:00:14.3: 0x00000201 | CNVR_AUX_MISC_CHIP
[ 192.777297] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 192.777339] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 192.777350] iwlwifi 0000:00:14.3: Firmware error during reconfiguration - reprobe!
[ 192.777439] iwlwifi 0000:00:14.3: FW error in SYNC CMD SCAN_CFG_CMD
[ 193.919625] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 193.919976] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 193.919978] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 193.919980] iwlwifi 0000:00:14.3: Loaded firmware version: 46.6bf1df06.0
[ 193.919981] iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 193.919983] iwlwifi 0000:00:14.3: 0x00A022F1 | trm_hw_status0
[ 193.919984] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 193.919985] iwlwifi 0000:00:14.3: 0x004882DA | branchlink2
[ 193.919986] iwlwifi 0000:00:14.3: 0x0047932A | interruptlink1
[ 193.919987] iwlwifi 0000:00:14.3: 0x000063AA | interruptlink2
[ 193.919988] iwlwifi 0000:00:14.3: 0x0001A83E | data1
[ 193.919989] iwlwifi 0000:00:14.3: 0x00001000 | data2
[ 193.919991] iwlwifi 0000:00:14.3: 0xF0000008 | data3
[ 193.919992] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 193.919993] iwlwifi 0000:00:14.3: 0x0003973B | tsf low
[ 193.919994] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 193.919995] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 193.919996] iwlwifi 0000:00:14.3: 0x0003973C | time gp2
[ 193.919997] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 193.919998] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 193.920000] iwlwifi 0000:00:14.3: 0x6BF1DF06 | uCode version minor
[ 193.920001] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 193.920002] iwlwifi 0000:00:14.3: 0x18C89008 | board version
[ 193.920003] iwlwifi 0000:00:14.3: 0x001E0177 | hcmd
[ 193.920004] iwlwifi 0000:00:14.3: 0x00122080 | isr0
[ 193.920005] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 193.920006] iwlwifi 0000:00:14.3: 0x08001802 | isr2
[ 193.920007] iwlwifi 0000:00:14.3: 0x404000C0 | isr3
[ 193.920008] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 193.920009] iwlwifi 0000:00:14.3: 0x001E0177 | last cmd Id
[ 193.920011] iwlwifi 0000:00:14.3: 0x0001A83E | wait_event
[ 193.920012] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 193.920013] iwlwifi 0000:00:14.3: 0x00000820 | l2p_duration
[ 193.920014] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 193.920015] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 193.920016] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 193.920017] iwlwifi 0000:00:14.3: 0x08081425 | timestamp
[ 193.920018] iwlwifi 0000:00:14.3: 0x0000183C | flow_handler
[ 193.920164] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 193.920165] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 193.920167] iwlwifi 0000:00:14.3: 0x20000034 | NMI_INTERRUPT_WDG
[ 193.920168] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 193.920169] iwlwifi 0000:00:14.3: 0xC008885E | umac branchlink2
[ 193.920170] iwlwifi 0000:00:14.3: 0x80454D04 | umac interruptlink1
[ 193.920171] iwlwifi 0000:00:14.3: 0xC00842AC | umac interruptlink2
[ 193.920172] iwlwifi 0000:00:14.3: 0x00000400 | umac data1
[ 193.920173] iwlwifi 0000:00:14.3: 0xC00842AC | umac data2
[ 193.920174] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 193.920176] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 193.920177] iwlwifi 0000:00:14.3: 0x6BF1DF06 | umac minor
[ 193.920178] iwlwifi 0000:00:14.3: 0x00039722 | frame pointer
[ 193.920179] iwlwifi 0000:00:14.3: 0xC0886B5C | stack pointer
[ 193.920180] iwlwifi 0000:00:14.3: 0x001F010C | last host cmd
[ 193.920181] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 193.920202] iwlwifi 0000:00:14.3: Fseq Registers:
[ 193.920211] iwlwifi 0000:00:14.3: 0xD9691F0C | FSEQ_ERROR_CODE
[ 193.920219] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 193.920227] iwlwifi 0000:00:14.3: 0x7F5B52FF | FSEQ_CNVIO_INIT_VERSION
[ 193.920236] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 193.920244] iwlwifi 0000:00:14.3: 0x56769A21 | FSEQ_TOP_CONTENT_VERSION
[ 193.920252] iwlwifi 0000:00:14.3: 0x22DD5979 | FSEQ_ALIVE_TOKEN
[ 193.920261] iwlwifi 0000:00:14.3: 0xAF64419A | FSEQ_CNVI_ID
[ 193.920269] iwlwifi 0000:00:14.3: 0xCF84088E | FSEQ_CNVR_ID
[ 193.920277] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 193.920288] iwlwifi 0000:00:14.3: 0x00000201 | CNVR_AUX_MISC_CHIP
[ 193.920299] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 193.920340] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 193.920405] iwlwifi 0000:00:14.3: iwlwifi transaction failed, dumping registers
[ 193.920407] iwlwifi 0000:00:14.3: iwlwifi device config registers:
[ 193.921124] iwlwifi 0000:00:14.3: 00000000: a3708086 00100406 02800010 00800010 a441c004 00000000 00000000 00000000
[ 193.921126] iwlwifi 0000:00:14.3: 00000020: 00000000 00000000 00000000 42a48086 00000000 000000c8 00000000 000001ff
[ 193.921128] iwlwifi 0000:00:14.3: 00000040: 00928010 10000ec0 00100c10 00000000 00000000 00000000 00000000 00000000
[ 193.921130] iwlwifi 0000:00:14.3: 00000060: 00000000 00080812 00000405 00000000 00000000 00000000 00000000 00000000
[ 193.921132] iwlwifi 0000:00:14.3: 00000080: 800f0011 00002000 00003000 00000000 00000000 00000000 00000000 00000000
[ 193.921133] iwlwifi 0000:00:14.3: 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 193.921135] iwlwifi 0000:00:14.3: 000000c0: 00000000 00000000 c823d001 0d000008 00804005 00000000 00000000 00000000
[ 193.921137] iwlwifi 0000:00:14.3: 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 193.921139] iwlwifi 0000:00:14.3: 00000100: 14c00000 ff000000 000000ff 00462031 00000000 00002000 00000000 00000000
[ 193.921141] iwlwifi 0000:00:14.3: 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 193.921142] iwlwifi 0000:00:14.3: 00000140: 00000000 00000000 00000000 16410018 00000000 0001001e 00481e1f 00000000
[ 193.921144] iwlwifi 0000:00:14.3: iwlwifi device memory mapped registers:
[ 193.921269] iwlwifi 0000:00:14.3: 00000000: 18c89008 00000040 00000000 00000000 00000000 00000000 00000000 00000000
[ 193.921271] iwlwifi 0000:00:14.3: 00000020: 00000000 0c040005 00000312 d55555d5 d55555d5 d55555d5 80008040 041f0040
[ 193.921295] iwlwifi 0000:00:14.3: FW error in SYNC CMD SCAN_CFG_CMD
[ 193.921634] iwlwifi 0000:00:14.3: Firmware not running - cannot dump error
[ 194.312816] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 194.313182] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 194.313186] iwlwifi 0000:00:14.3: Status: 0x00000050, count: 6
[ 194.313189] iwlwifi 0000:00:14.3: Loaded firmware version: 46.6bf1df06.0
[ 194.313193] iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 194.313196] iwlwifi 0000:00:14.3: 0x00A022F1 | trm_hw_status0
[ 194.313198] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 194.313201] iwlwifi 0000:00:14.3: 0x004882DA | branchlink2
[ 194.313203] iwlwifi 0000:00:14.3: 0x0047932A | interruptlink1
[ 194.313205] iwlwifi 0000:00:14.3: 0x0000B072 | interruptlink2
[ 194.313208] iwlwifi 0000:00:14.3: 0x0001A83E | data1
[ 194.313210] iwlwifi 0000:00:14.3: 0x00001000 | data2
[ 194.313213] iwlwifi 0000:00:14.3: 0xF0000008 | data3
[ 194.313215] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 194.313217] iwlwifi 0000:00:14.3: 0x00039AD6 | tsf low
[ 194.313220] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 194.313223] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 194.313225] iwlwifi 0000:00:14.3: 0x00039AD6 | time gp2
[ 194.313228] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 194.313230] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 194.313233] iwlwifi 0000:00:14.3: 0x6BF1DF06 | uCode version minor
[ 194.313235] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 194.313237] iwlwifi 0000:00:14.3: 0x18C89008 | board version
[ 194.313240] iwlwifi 0000:00:14.3: 0x001D0177 | hcmd
[ 194.313242] iwlwifi 0000:00:14.3: 0x00122080 | isr0
[ 194.313244] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 194.313247] iwlwifi 0000:00:14.3: 0x08001802 | isr2
[ 194.313249] iwlwifi 0000:00:14.3: 0x404001C0 | isr3
[ 194.313251] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 194.313254] iwlwifi 0000:00:14.3: 0x001D0177 | last cmd Id
[ 194.313256] iwlwifi 0000:00:14.3: 0x0001A83E | wait_event
[ 194.313258] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 194.313261] iwlwifi 0000:00:14.3: 0x00000820 | l2p_duration
[ 194.313263] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 194.313265] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 194.313268] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 194.313270] iwlwifi 0000:00:14.3: 0x08081425 | timestamp
[ 194.313273] iwlwifi 0000:00:14.3: 0x0000183C | flow_handler
[ 194.313420] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 194.313423] iwlwifi 0000:00:14.3: Status: 0x00000050, count: 7
[ 194.313426] iwlwifi 0000:00:14.3: 0x20000034 | NMI_INTERRUPT_WDG
[ 194.313428] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 194.313430] iwlwifi 0000:00:14.3: 0xC008885E | umac branchlink2
[ 194.313433] iwlwifi 0000:00:14.3: 0x80454D04 | umac interruptlink1
[ 194.313435] iwlwifi 0000:00:14.3: 0xC00842AC | umac interruptlink2
[ 194.313437] iwlwifi 0000:00:14.3: 0x00000400 | umac data1
[ 194.313440] iwlwifi 0000:00:14.3: 0xC00842AC | umac data2
[ 194.313442] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 194.313444] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 194.313447] iwlwifi 0000:00:14.3: 0x6BF1DF06 | umac minor
[ 194.313449] iwlwifi 0000:00:14.3: 0x00039ABE | frame pointer
[ 194.313451] iwlwifi 0000:00:14.3: 0xC0886B5C | stack pointer
[ 194.313454] iwlwifi 0000:00:14.3: 0x001E010C | last host cmd
[ 194.313456] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 194.313475] iwlwifi 0000:00:14.3: Fseq Registers:
[ 194.313486] iwlwifi 0000:00:14.3: 0xD9691F0C | FSEQ_ERROR_CODE
[ 194.313496] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 194.313506] iwlwifi 0000:00:14.3: 0x7F5B52FF | FSEQ_CNVIO_INIT_VERSION
[ 194.313515] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 194.313524] iwlwifi 0000:00:14.3: 0x56769A21 | FSEQ_TOP_CONTENT_VERSION
[ 194.313534] iwlwifi 0000:00:14.3: 0x22DD5979 | FSEQ_ALIVE_TOKEN
[ 194.313543] iwlwifi 0000:00:14.3: 0xAF64419A | FSEQ_CNVI_ID
[ 194.313553] iwlwifi 0000:00:14.3: 0xCF84088E | FSEQ_CNVR_ID
[ 194.313563] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 194.313575] iwlwifi 0000:00:14.3: 0x00000201 | CNVR_AUX_MISC_CHIP
[ 194.313587] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 194.313629] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 194.313640] iwlwifi 0000:00:14.3: Firmware error during reconfiguration - reprobe!
[ 194.313715] iwlwifi 0000:00:14.3: FW error in SYNC CMD SCAN_CFG_CMD
[ 194.715254] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 194.715621] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 194.715626] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 194.715628] iwlwifi 0000:00:14.3: Loaded firmware version: 46.6bf1df06.0
[ 194.715632] iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 194.715635] iwlwifi 0000:00:14.3: 0x00A0A2F1 | trm_hw_status0
[ 194.715638] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 194.715640] iwlwifi 0000:00:14.3: 0x004882DA | branchlink2
[ 194.715643] iwlwifi 0000:00:14.3: 0x0047932A | interruptlink1
[ 194.715645] iwlwifi 0000:00:14.3: 0x0000B0D0 | interruptlink2
[ 194.715647] iwlwifi 0000:00:14.3: 0x0001A83E | data1
[ 194.715650] iwlwifi 0000:00:14.3: 0x00001000 | data2
[ 194.715652] iwlwifi 0000:00:14.3: 0xF0000008 | data3
[ 194.715655] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 194.715657] iwlwifi 0000:00:14.3: 0x000399A4 | tsf low
[ 194.715659] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 194.715662] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 194.715664] iwlwifi 0000:00:14.3: 0x000399A4 | time gp2
[ 194.715666] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 194.715669] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 194.715671] iwlwifi 0000:00:14.3: 0x6BF1DF06 | uCode version minor
[ 194.715674] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 194.715676] iwlwifi 0000:00:14.3: 0x18C89008 | board version
[ 194.715679] iwlwifi 0000:00:14.3: 0x001D0177 | hcmd
[ 194.715681] iwlwifi 0000:00:14.3: 0x20122080 | isr0
[ 194.715683] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 194.715686] iwlwifi 0000:00:14.3: 0x08001802 | isr2
[ 194.715688] iwlwifi 0000:00:14.3: 0x404001C0 | isr3
[ 194.715690] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 194.715693] iwlwifi 0000:00:14.3: 0x001D0177 | last cmd Id
[ 194.715695] iwlwifi 0000:00:14.3: 0x0001A83E | wait_event
[ 194.715698] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 194.715700] iwlwifi 0000:00:14.3: 0x00000820 | l2p_duration
[ 194.715702] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 194.715705] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 194.715707] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 194.715709] iwlwifi 0000:00:14.3: 0x08081425 | timestamp
[ 194.715712] iwlwifi 0000:00:14.3: 0x0000183C | flow_handler
[ 194.715859] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 194.715862] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 194.715865] iwlwifi 0000:00:14.3: 0x20000034 | NMI_INTERRUPT_WDG
[ 194.715867] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 194.715870] iwlwifi 0000:00:14.3: 0xC008885E | umac branchlink2
[ 194.715872] iwlwifi 0000:00:14.3: 0x80454D04 | umac interruptlink1
[ 194.715874] iwlwifi 0000:00:14.3: 0xC00842AC | umac interruptlink2
[ 194.715877] iwlwifi 0000:00:14.3: 0x00000400 | umac data1
[ 194.715879] iwlwifi 0000:00:14.3: 0xC00842AC | umac data2
[ 194.715882] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 194.715884] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 194.715886] iwlwifi 0000:00:14.3: 0x6BF1DF06 | umac minor
[ 194.715889] iwlwifi 0000:00:14.3: 0x0003998C | frame pointer
[ 194.715891] iwlwifi 0000:00:14.3: 0xC0886B5C | stack pointer
[ 194.715893] iwlwifi 0000:00:14.3: 0x001E010C | last host cmd
[ 194.715896] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 194.715915] iwlwifi 0000:00:14.3: Fseq Registers:
[ 194.715925] iwlwifi 0000:00:14.3: 0xD9691F0C | FSEQ_ERROR_CODE
[ 194.715935] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 194.715945] iwlwifi 0000:00:14.3: 0x7F5B52FF | FSEQ_CNVIO_INIT_VERSION
[ 194.715955] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 194.715965] iwlwifi 0000:00:14.3: 0x56769A21 | FSEQ_TOP_CONTENT_VERSION
[ 194.715975] iwlwifi 0000:00:14.3: 0x22DD5979 | FSEQ_ALIVE_TOKEN
[ 194.715984] iwlwifi 0000:00:14.3: 0xAF64419A | FSEQ_CNVI_ID
[ 194.715994] iwlwifi 0000:00:14.3: 0xCF84088E | FSEQ_CNVR_ID
[ 194.716004] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 194.716016] iwlwifi 0000:00:14.3: 0x00000201 | CNVR_AUX_MISC_CHIP
[ 194.716028] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 194.716070] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 194.716157] iwlwifi 0000:00:14.3: FW error in SYNC CMD SCAN_CFG_CMD
[ 194.716622] iwlwifi 0000:00:14.3: Firmware not running - cannot dump error
[ 195.747738] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 195.748091] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 195.748093] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 195.748094] iwlwifi 0000:00:14.3: Loaded firmware version: 46.6bf1df06.0
[ 195.748096] iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 195.748097] iwlwifi 0000:00:14.3: 0x00A022F1 | trm_hw_status0
[ 195.748099] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 195.748100] iwlwifi 0000:00:14.3: 0x004882DA | branchlink2
[ 195.748101] iwlwifi 0000:00:14.3: 0x0047932A | interruptlink1
[ 195.748102] iwlwifi 0000:00:14.3: 0x0000B0D0 | interruptlink2
[ 195.748103] iwlwifi 0000:00:14.3: 0x0001A83E | data1
[ 195.748105] iwlwifi 0000:00:14.3: 0x00001000 | data2
[ 195.748106] iwlwifi 0000:00:14.3: 0xF0000008 | data3
[ 195.748107] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 195.748108] iwlwifi 0000:00:14.3: 0x000396C4 | tsf low
[ 195.748110] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 195.748111] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 195.748112] iwlwifi 0000:00:14.3: 0x000396C5 | time gp2
[ 195.748113] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 195.748114] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 195.748116] iwlwifi 0000:00:14.3: 0x6BF1DF06 | uCode version minor
[ 195.748117] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 195.748118] iwlwifi 0000:00:14.3: 0x18C89008 | board version
[ 195.748119] iwlwifi 0000:00:14.3: 0x001E0177 | hcmd
[ 195.748121] iwlwifi 0000:00:14.3: 0x00122080 | isr0
[ 195.748122] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 195.748123] iwlwifi 0000:00:14.3: 0x08001802 | isr2
[ 195.748124] iwlwifi 0000:00:14.3: 0x404001C0 | isr3
[ 195.748125] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 195.748126] iwlwifi 0000:00:14.3: 0x001E0177 | last cmd Id
[ 195.748128] iwlwifi 0000:00:14.3: 0x0001A83E | wait_event
[ 195.748129] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 195.748130] iwlwifi 0000:00:14.3: 0x00000820 | l2p_duration
[ 195.748131] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 195.748132] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 195.748133] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 195.748135] iwlwifi 0000:00:14.3: 0x08081425 | timestamp
[ 195.748136] iwlwifi 0000:00:14.3: 0x0000183C | flow_handler
[ 195.748321] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 195.748323] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 195.748325] iwlwifi 0000:00:14.3: 0x20000034 | NMI_INTERRUPT_WDG
[ 195.748327] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 195.748330] iwlwifi 0000:00:14.3: 0xC008885E | umac branchlink2
[ 195.748334] iwlwifi 0000:00:14.3: 0x80454D04 | umac interruptlink1
[ 195.748336] iwlwifi 0000:00:14.3: 0xC00842AC | umac interruptlink2
[ 195.748338] iwlwifi 0000:00:14.3: 0x00000400 | umac data1
[ 195.748340] iwlwifi 0000:00:14.3: 0xC00842AC | umac data2
[ 195.748342] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 195.748344] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 195.748346] iwlwifi 0000:00:14.3: 0x6BF1DF06 | umac minor
[ 195.748349] iwlwifi 0000:00:14.3: 0x000396AB | frame pointer
[ 195.748351] iwlwifi 0000:00:14.3: 0xC0886B5C | stack pointer
[ 195.748353] iwlwifi 0000:00:14.3: 0x001F010C | last host cmd
[ 195.748356] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 195.748375] iwlwifi 0000:00:14.3: Fseq Registers:
[ 195.748403] iwlwifi 0000:00:14.3: 0xD9691F0C | FSEQ_ERROR_CODE
[ 195.748415] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 195.748425] iwlwifi 0000:00:14.3: 0x7F5B52FF | FSEQ_CNVIO_INIT_VERSION
[ 195.748434] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 195.748443] iwlwifi 0000:00:14.3: 0x56769A21 | FSEQ_TOP_CONTENT_VERSION
[ 195.748453] iwlwifi 0000:00:14.3: 0x22DD5979 | FSEQ_ALIVE_TOKEN
[ 195.748463] iwlwifi 0000:00:14.3: 0xAF64419A | FSEQ_CNVI_ID
[ 195.748473] iwlwifi 0000:00:14.3: 0xCF84088E | FSEQ_CNVR_ID
[ 195.748483] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 195.748495] iwlwifi 0000:00:14.3: 0x00000201 | CNVR_AUX_MISC_CHIP
[ 195.748506] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 195.748549] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 195.748618] iwlwifi 0000:00:14.3: iwlwifi transaction failed, dumping registers
[ 195.748621] iwlwifi 0000:00:14.3: iwlwifi device config registers:
[ 195.749301] iwlwifi 0000:00:14.3: 00000000: a3708086 00100406 02800010 00800010 a441c004 00000000 00000000 00000000
[ 195.749304] iwlwifi 0000:00:14.3: 00000020: 00000000 00000000 00000000 42a48086 00000000 000000c8 00000000 000001ff
[ 195.749306] iwlwifi 0000:00:14.3: 00000040: 00928010 10000ec0 00100c10 00000000 00000000 00000000 00000000 00000000
[ 195.749308] iwlwifi 0000:00:14.3: 00000060: 00000000 00080812 00000405 00000000 00000000 00000000 00000000 00000000
[ 195.749311] iwlwifi 0000:00:14.3: 00000080: 800f0011 00002000 00003000 00000000 00000000 00000000 00000000 00000000
[ 195.749313] iwlwifi 0000:00:14.3: 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 195.749315] iwlwifi 0000:00:14.3: 000000c0: 00000000 00000000 c823d001 0d000008 00804005 00000000 00000000 00000000
[ 195.749317] iwlwifi 0000:00:14.3: 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 195.749319] iwlwifi 0000:00:14.3: 00000100: 14c00000 ff000000 000000ff 00462031 00000000 00002000 00000000 00000000
[ 195.749321] iwlwifi 0000:00:14.3: 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 195.749324] iwlwifi 0000:00:14.3: 00000140: 00000000 00000000 00000000 16410018 00000000 0001001e 00481e1f 00000000
[ 195.749326] iwlwifi 0000:00:14.3: iwlwifi device memory mapped registers:
[ 195.749451] iwlwifi 0000:00:14.3: 00000000: 18c89008 00000040 00000000 00000000 00000000 00000000 00000000 00000000
[ 195.749453] iwlwifi 0000:00:14.3: 00000020: 00000000 0c040005 00000312 d55555d5 d55555d5 d55555d5 80008040 041f0040
[ 195.749478] iwlwifi 0000:00:14.3: FW error in SYNC CMD SCAN_CFG_CMD
[ 195.749767] iwlwifi 0000:00:14.3: Firmware not running - cannot dump error
[ 196.141236] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 196.141634] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 196.141640] iwlwifi 0000:00:14.3: Status: 0x00000050, count: 6
[ 196.141643] iwlwifi 0000:00:14.3: Loaded firmware version: 46.6bf1df06.0
[ 196.141649] iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 196.141652] iwlwifi 0000:00:14.3: 0x00A022F1 | trm_hw_status0
[ 196.141661] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 196.141665] iwlwifi 0000:00:14.3: 0x004882DA | branchlink2
[ 196.141669] iwlwifi 0000:00:14.3: 0x0047932A | interruptlink1
[ 196.141673] iwlwifi 0000:00:14.3: 0x0000B072 | interruptlink2
[ 196.141676] iwlwifi 0000:00:14.3: 0x0001A83E | data1
[ 196.141680] iwlwifi 0000:00:14.3: 0x00001000 | data2
[ 196.141684] iwlwifi 0000:00:14.3: 0xF0000008 | data3
[ 196.141688] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 196.141692] iwlwifi 0000:00:14.3: 0x000398BF | tsf low
[ 196.141697] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 196.141701] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 196.141705] iwlwifi 0000:00:14.3: 0x000398BF | time gp2
[ 196.141709] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 196.141713] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 196.141718] iwlwifi 0000:00:14.3: 0x6BF1DF06 | uCode version minor
[ 196.141722] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 196.141726] iwlwifi 0000:00:14.3: 0x18C89008 | board version
[ 196.141730] iwlwifi 0000:00:14.3: 0x001D0177 | hcmd
[ 196.141734] iwlwifi 0000:00:14.3: 0x00122080 | isr0
[ 196.141738] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 196.141742] iwlwifi 0000:00:14.3: 0x08001802 | isr2
[ 196.141747] iwlwifi 0000:00:14.3: 0x404001C0 | isr3
[ 196.141751] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 196.141755] iwlwifi 0000:00:14.3: 0x001D0177 | last cmd Id
[ 196.141759] iwlwifi 0000:00:14.3: 0x0001A83E | wait_event
[ 196.141764] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 196.141768] iwlwifi 0000:00:14.3: 0x00000820 | l2p_duration
[ 196.141773] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 196.141778] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 196.141782] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 196.141786] iwlwifi 0000:00:14.3: 0x08081425 | timestamp
[ 196.141791] iwlwifi 0000:00:14.3: 0x0000183C | flow_handler
[ 196.141943] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 196.141949] iwlwifi 0000:00:14.3: Status: 0x00000050, count: 7
[ 196.141954] iwlwifi 0000:00:14.3: 0x20000034 | NMI_INTERRUPT_WDG
[ 196.141959] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 196.141963] iwlwifi 0000:00:14.3: 0xC008885E | umac branchlink2
[ 196.141967] iwlwifi 0000:00:14.3: 0x80454D04 | umac interruptlink1
[ 196.141972] iwlwifi 0000:00:14.3: 0xC00842AC | umac interruptlink2
[ 196.141978] iwlwifi 0000:00:14.3: 0x00000400 | umac data1
[ 196.141982] iwlwifi 0000:00:14.3: 0xC00842AC | umac data2
[ 196.141987] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 196.141991] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 196.141995] iwlwifi 0000:00:14.3: 0x6BF1DF06 | umac minor
[ 196.142000] iwlwifi 0000:00:14.3: 0x000398A7 | frame pointer
[ 196.142005] iwlwifi 0000:00:14.3: 0xC0886B5C | stack pointer
[ 196.142009] iwlwifi 0000:00:14.3: 0x001E010C | last host cmd
[ 196.142014] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 196.142036] iwlwifi 0000:00:14.3: Fseq Registers:
[ 196.142049] iwlwifi 0000:00:14.3: 0xD9691F0C | FSEQ_ERROR_CODE
[ 196.142061] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 196.142073] iwlwifi 0000:00:14.3: 0x7F5B52FF | FSEQ_CNVIO_INIT_VERSION
[ 196.142085] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 196.142097] iwlwifi 0000:00:14.3: 0x56769A21 | FSEQ_TOP_CONTENT_VERSION
[ 196.142109] iwlwifi 0000:00:14.3: 0x22DD5979 | FSEQ_ALIVE_TOKEN
[ 196.142121] iwlwifi 0000:00:14.3: 0xAF64419A | FSEQ_CNVI_ID
[ 196.142133] iwlwifi 0000:00:14.3: 0xCF84088E | FSEQ_CNVR_ID
[ 196.142146] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 196.142160] iwlwifi 0000:00:14.3: 0x00000201 | CNVR_AUX_MISC_CHIP
[ 196.142176] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 196.142221] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 196.142234] iwlwifi 0000:00:14.3: Firmware error during reconfiguration - reprobe!
[ 196.142310] iwlwifi 0000:00:14.3: FW error in SYNC CMD SCAN_CFG_CMD
[ 196.544751] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 196.545152] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 196.545160] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 196.545164] iwlwifi 0000:00:14.3: Loaded firmware version: 46.6bf1df06.0
[ 196.545169] iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 196.545173] iwlwifi 0000:00:14.3: 0x00A022F1 | trm_hw_status0
[ 196.545177] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 196.545180] iwlwifi 0000:00:14.3: 0x004882DA | branchlink2
[ 196.545184] iwlwifi 0000:00:14.3: 0x0047932A | interruptlink1
[ 196.545188] iwlwifi 0000:00:14.3: 0x0000B072 | interruptlink2
[ 196.545192] iwlwifi 0000:00:14.3: 0x0001A83E | data1
[ 196.545195] iwlwifi 0000:00:14.3: 0x00001000 | data2
[ 196.545204] iwlwifi 0000:00:14.3: 0xF0000008 | data3
[ 196.545208] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 196.545212] iwlwifi 0000:00:14.3: 0x00039B7A | tsf low
[ 196.545215] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 196.545219] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 196.545222] iwlwifi 0000:00:14.3: 0x00039B7A | time gp2
[ 196.545226] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 196.545231] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 196.545235] iwlwifi 0000:00:14.3: 0x6BF1DF06 | uCode version minor
[ 196.545239] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 196.545243] iwlwifi 0000:00:14.3: 0x18C89008 | board version
[ 196.545248] iwlwifi 0000:00:14.3: 0x001D0177 | hcmd
[ 196.545252] iwlwifi 0000:00:14.3: 0x00122080 | isr0
[ 196.545256] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 196.545260] iwlwifi 0000:00:14.3: 0x08001802 | isr2
[ 196.545264] iwlwifi 0000:00:14.3: 0x404001C0 | isr3
[ 196.545268] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 196.545273] iwlwifi 0000:00:14.3: 0x001D0177 | last cmd Id
[ 196.545278] iwlwifi 0000:00:14.3: 0x0001A83E | wait_event
[ 196.545281] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 196.545284] iwlwifi 0000:00:14.3: 0x00000820 | l2p_duration
[ 196.545288] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 196.545292] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 196.545296] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 196.545301] iwlwifi 0000:00:14.3: 0x08081425 | timestamp
[ 196.545305] iwlwifi 0000:00:14.3: 0x0000183C | flow_handler
[ 196.545457] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 196.545463] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 196.545468] iwlwifi 0000:00:14.3: 0x20000034 | NMI_INTERRUPT_WDG
[ 196.545472] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 196.545476] iwlwifi 0000:00:14.3: 0xC008885E | umac branchlink2
[ 196.545481] iwlwifi 0000:00:14.3: 0x80454D04 | umac interruptlink1
[ 196.545485] iwlwifi 0000:00:14.3: 0xC00842AC | umac interruptlink2
[ 196.545491] iwlwifi 0000:00:14.3: 0x00000400 | umac data1
[ 196.545494] iwlwifi 0000:00:14.3: 0xC00842AC | umac data2
[ 196.545499] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 196.545504] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 196.545509] iwlwifi 0000:00:14.3: 0x6BF1DF06 | umac minor
[ 196.545513] iwlwifi 0000:00:14.3: 0x00039B62 | frame pointer
[ 196.545519] iwlwifi 0000:00:14.3: 0xC0886B5C | stack pointer
[ 196.545525] iwlwifi 0000:00:14.3: 0x001E010C | last host cmd
[ 196.545529] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 196.545551] iwlwifi 0000:00:14.3: Fseq Registers:
[ 196.545563] iwlwifi 0000:00:14.3: 0xD9691F0C | FSEQ_ERROR_CODE
[ 196.545577] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 196.545590] iwlwifi 0000:00:14.3: 0x7F5B52FF | FSEQ_CNVIO_INIT_VERSION
[ 196.545604] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 196.545617] iwlwifi 0000:00:14.3: 0x56769A21 | FSEQ_TOP_CONTENT_VERSION
[ 196.545631] iwlwifi 0000:00:14.3: 0x22DD5979 | FSEQ_ALIVE_TOKEN
[ 196.545643] iwlwifi 0000:00:14.3: 0xAF64419A | FSEQ_CNVI_ID
[ 196.545656] iwlwifi 0000:00:14.3: 0xCF84088E | FSEQ_CNVR_ID
[ 196.545667] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 196.545682] iwlwifi 0000:00:14.3: 0x00000201 | CNVR_AUX_MISC_CHIP
[ 196.545696] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 196.545742] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 196.545874] iwlwifi 0000:00:14.3: FW error in SYNC CMD SCAN_CFG_CMD
[ 196.546352] iwlwifi 0000:00:14.3: Firmware not running - cannot dump error
[ 197.585366] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 197.585722] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 197.585724] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 197.585725] iwlwifi 0000:00:14.3: Loaded firmware version: 46.6bf1df06.0
[ 197.585726] iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 197.585727] iwlwifi 0000:00:14.3: 0x00A022F1 | trm_hw_status0
[ 197.585728] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 197.585729] iwlwifi 0000:00:14.3: 0x004882DA | branchlink2
[ 197.585730] iwlwifi 0000:00:14.3: 0x0047932A | interruptlink1
[ 197.585731] iwlwifi 0000:00:14.3: 0x0000B0D0 | interruptlink2
[ 197.585732] iwlwifi 0000:00:14.3: 0x0001A83E | data1
[ 197.585733] iwlwifi 0000:00:14.3: 0x00001000 | data2
[ 197.585734] iwlwifi 0000:00:14.3: 0xF0000008 | data3
[ 197.585735] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 197.585736] iwlwifi 0000:00:14.3: 0x000396E0 | tsf low
[ 197.585737] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 197.585737] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 197.585738] iwlwifi 0000:00:14.3: 0x000396E1 | time gp2
[ 197.585739] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 197.585740] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 197.585741] iwlwifi 0000:00:14.3: 0x6BF1DF06 | uCode version minor
[ 197.585742] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 197.585743] iwlwifi 0000:00:14.3: 0x18C89008 | board version
[ 197.585744] iwlwifi 0000:00:14.3: 0x001E0177 | hcmd
[ 197.585745] iwlwifi 0000:00:14.3: 0x00122080 | isr0
[ 197.585746] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 197.585746] iwlwifi 0000:00:14.3: 0x08001802 | isr2
[ 197.585747] iwlwifi 0000:00:14.3: 0x404001C0 | isr3
[ 197.585748] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 197.585749] iwlwifi 0000:00:14.3: 0x001E0177 | last cmd Id
[ 197.585750] iwlwifi 0000:00:14.3: 0x0001A83E | wait_event
[ 197.585751] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 197.585752] iwlwifi 0000:00:14.3: 0x00000820 | l2p_duration
[ 197.585753] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 197.585754] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 197.585754] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 197.585755] iwlwifi 0000:00:14.3: 0x08081425 | timestamp
[ 197.585756] iwlwifi 0000:00:14.3: 0x0000183C | flow_handler
[ 197.585902] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 197.585903] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 197.585904] iwlwifi 0000:00:14.3: 0x20000034 | NMI_INTERRUPT_WDG
[ 197.585905] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 197.585906] iwlwifi 0000:00:14.3: 0xC008885E | umac branchlink2
[ 197.585907] iwlwifi 0000:00:14.3: 0x80454D04 | umac interruptlink1
[ 197.585908] iwlwifi 0000:00:14.3: 0xC00842AC | umac interruptlink2
[ 197.585909] iwlwifi 0000:00:14.3: 0x00000400 | umac data1
[ 197.585909] iwlwifi 0000:00:14.3: 0xC00842AC | umac data2
[ 197.585910] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 197.585911] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 197.585912] iwlwifi 0000:00:14.3: 0x6BF1DF06 | umac minor
[ 197.585913] iwlwifi 0000:00:14.3: 0x000396C7 | frame pointer
[ 197.585914] iwlwifi 0000:00:14.3: 0xC0886B5C | stack pointer
[ 197.585915] iwlwifi 0000:00:14.3: 0x001F010C | last host cmd
[ 197.585916] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 197.585940] iwlwifi 0000:00:14.3: Fseq Registers:
[ 197.585948] iwlwifi 0000:00:14.3: 0xD9691F0C | FSEQ_ERROR_CODE
[ 197.585956] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 197.585965] iwlwifi 0000:00:14.3: 0x7F5B52FF | FSEQ_CNVIO_INIT_VERSION
[ 197.585973] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 197.585981] iwlwifi 0000:00:14.3: 0x56769A21 | FSEQ_TOP_CONTENT_VERSION
[ 197.585990] iwlwifi 0000:00:14.3: 0x22DD5979 | FSEQ_ALIVE_TOKEN
[ 197.585997] iwlwifi 0000:00:14.3: 0xAF64419A | FSEQ_CNVI_ID
[ 197.586006] iwlwifi 0000:00:14.3: 0xCF84088E | FSEQ_CNVR_ID
[ 197.586015] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 197.586025] iwlwifi 0000:00:14.3: 0x00000201 | CNVR_AUX_MISC_CHIP
[ 197.586036] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 197.586077] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 197.586138] iwlwifi 0000:00:14.3: iwlwifi transaction failed, dumping registers
[ 197.586140] iwlwifi 0000:00:14.3: iwlwifi device config registers:
[ 197.586821] iwlwifi 0000:00:14.3: 00000000: a3708086 00100406 02800010 00800010 a441c004 00000000 00000000 00000000
[ 197.586824] iwlwifi 0000:00:14.3: 00000020: 00000000 00000000 00000000 42a48086 00000000 000000c8 00000000 000001ff
[ 197.586826] iwlwifi 0000:00:14.3: 00000040: 00928010 10000ec0 00100c10 00000000 00000000 00000000 00000000 00000000
[ 197.586828] iwlwifi 0000:00:14.3: 00000060: 00000000 00080812 00000405 00000000 00000000 00000000 00000000 00000000
[ 197.586830] iwlwifi 0000:00:14.3: 00000080: 800f0011 00002000 00003000 00000000 00000000 00000000 00000000 00000000
[ 197.586832] iwlwifi 0000:00:14.3: 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 197.586834] iwlwifi 0000:00:14.3: 000000c0: 00000000 00000000 c823d001 0d000008 00804005 00000000 00000000 00000000
[ 197.586835] iwlwifi 0000:00:14.3: 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 197.586837] iwlwifi 0000:00:14.3: 00000100: 14c00000 ff000000 000000ff 00462031 00000000 00002000 00000000 00000000
[ 197.586839] iwlwifi 0000:00:14.3: 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 197.586841] iwlwifi 0000:00:14.3: 00000140: 00000000 00000000 00000000 16410018 00000000 0001001e 00481e1f 00000000
[ 197.586843] iwlwifi 0000:00:14.3: iwlwifi device memory mapped registers:
[ 197.586891] iwlwifi 0000:00:14.3: 00000000: 18c89008 00000040 00000000 00000000 00000000 00000000 00000000 00000000
[ 197.586893] iwlwifi 0000:00:14.3: 00000020: 00000000 0c040005 00000312 d55555d5 d55555d5 d55555d5 80008040 041f0040
[ 197.586910] iwlwifi 0000:00:14.3: FW error in SYNC CMD SCAN_CFG_CMD
[ 197.587276] iwlwifi 0000:00:14.3: Firmware not running - cannot dump error
[ 197.979838] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 197.980204] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 197.980208] iwlwifi 0000:00:14.3: Status: 0x00000050, count: 6
[ 197.980211] iwlwifi 0000:00:14.3: Loaded firmware version: 46.6bf1df06.0
[ 197.980215] iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 197.980218] iwlwifi 0000:00:14.3: 0x00A022F1 | trm_hw_status0
[ 197.980220] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 197.980223] iwlwifi 0000:00:14.3: 0x004882DA | branchlink2
[ 197.980225] iwlwifi 0000:00:14.3: 0x0047932A | interruptlink1
[ 197.980227] iwlwifi 0000:00:14.3: 0x00006368 | interruptlink2
[ 197.980230] iwlwifi 0000:00:14.3: 0x0001A83E | data1
[ 197.980232] iwlwifi 0000:00:14.3: 0x00001000 | data2
[ 197.980235] iwlwifi 0000:00:14.3: 0xF0000008 | data3
[ 197.980237] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 197.980239] iwlwifi 0000:00:14.3: 0x00039C39 | tsf low
[ 197.980242] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 197.980244] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 197.980246] iwlwifi 0000:00:14.3: 0x00039C39 | time gp2
[ 197.980249] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 197.980251] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 197.980254] iwlwifi 0000:00:14.3: 0x6BF1DF06 | uCode version minor
[ 197.980256] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 197.980259] iwlwifi 0000:00:14.3: 0x18C89008 | board version
[ 197.980261] iwlwifi 0000:00:14.3: 0x001D0177 | hcmd
[ 197.980264] iwlwifi 0000:00:14.3: 0x00122000 | isr0
[ 197.980266] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 197.980268] iwlwifi 0000:00:14.3: 0x08001802 | isr2
[ 197.980271] iwlwifi 0000:00:14.3: 0x404000C0 | isr3
[ 197.980273] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 197.980275] iwlwifi 0000:00:14.3: 0x001D0177 | last cmd Id
[ 197.980278] iwlwifi 0000:00:14.3: 0x0001A83E | wait_event
[ 197.980280] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 197.980282] iwlwifi 0000:00:14.3: 0x00000820 | l2p_duration
[ 197.980285] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 197.980287] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 197.980289] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 197.980292] iwlwifi 0000:00:14.3: 0x08081425 | timestamp
[ 197.980294] iwlwifi 0000:00:14.3: 0x0000183C | flow_handler
[ 197.980442] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 197.980445] iwlwifi 0000:00:14.3: Status: 0x00000050, count: 7
[ 197.980448] iwlwifi 0000:00:14.3: 0x20000034 | NMI_INTERRUPT_WDG
[ 197.980450] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 197.980453] iwlwifi 0000:00:14.3: 0xC008885E | umac branchlink2
[ 197.980455] iwlwifi 0000:00:14.3: 0x80454D04 | umac interruptlink1
[ 197.980458] iwlwifi 0000:00:14.3: 0xC00842AC | umac interruptlink2
[ 197.980460] iwlwifi 0000:00:14.3: 0x00000400 | umac data1
[ 197.980462] iwlwifi 0000:00:14.3: 0xC00842AC | umac data2
[ 197.980465] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 197.980467] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 197.980469] iwlwifi 0000:00:14.3: 0x6BF1DF06 | umac minor
[ 197.980471] iwlwifi 0000:00:14.3: 0x00039C21 | frame pointer
[ 197.980474] iwlwifi 0000:00:14.3: 0xC0886B5C | stack pointer
[ 197.980476] iwlwifi 0000:00:14.3: 0x001E010C | last host cmd
[ 197.980479] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 197.980498] iwlwifi 0000:00:14.3: Fseq Registers:
[ 197.980508] iwlwifi 0000:00:14.3: 0xD9691F0C | FSEQ_ERROR_CODE
[ 197.980518] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 197.980528] iwlwifi 0000:00:14.3: 0x7F5B52FF | FSEQ_CNVIO_INIT_VERSION
[ 197.980538] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 197.980547] iwlwifi 0000:00:14.3: 0x56769A21 | FSEQ_TOP_CONTENT_VERSION
[ 197.980557] iwlwifi 0000:00:14.3: 0x22DD5979 | FSEQ_ALIVE_TOKEN
[ 197.980567] iwlwifi 0000:00:14.3: 0xAF64419A | FSEQ_CNVI_ID
[ 197.980576] iwlwifi 0000:00:14.3: 0xCF84088E | FSEQ_CNVR_ID
[ 197.980586] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 197.980598] iwlwifi 0000:00:14.3: 0x00000201 | CNVR_AUX_MISC_CHIP
[ 197.980610] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 197.980652] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 197.980663] iwlwifi 0000:00:14.3: Firmware error during reconfiguration - reprobe!
[ 197.980751] iwlwifi 0000:00:14.3: FW error in SYNC CMD SCAN_CFG_CMD
[ 199.029052] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 199.029404] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 199.029406] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 199.029407] iwlwifi 0000:00:14.3: Loaded firmware version: 46.6bf1df06.0
[ 199.029409] iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 199.029410] iwlwifi 0000:00:14.3: 0x00A022F1 | trm_hw_status0
[ 199.029411] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 199.029412] iwlwifi 0000:00:14.3: 0x004882DA | branchlink2
[ 199.029414] iwlwifi 0000:00:14.3: 0x0047932A | interruptlink1
[ 199.029415] iwlwifi 0000:00:14.3: 0x0000B0D0 | interruptlink2
[ 199.029416] iwlwifi 0000:00:14.3: 0x0001A83E | data1
[ 199.029417] iwlwifi 0000:00:14.3: 0x00001000 | data2
[ 199.029418] iwlwifi 0000:00:14.3: 0xF0000008 | data3
[ 199.029419] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 199.029420] iwlwifi 0000:00:14.3: 0x000396E6 | tsf low
[ 199.029422] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 199.029423] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 199.029424] iwlwifi 0000:00:14.3: 0x000396E7 | time gp2
[ 199.029425] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 199.029426] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 199.029427] iwlwifi 0000:00:14.3: 0x6BF1DF06 | uCode version minor
[ 199.029428] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 199.029430] iwlwifi 0000:00:14.3: 0x18C89008 | board version
[ 199.029431] iwlwifi 0000:00:14.3: 0x001E0177 | hcmd
[ 199.029432] iwlwifi 0000:00:14.3: 0x00122080 | isr0
[ 199.029433] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 199.029434] iwlwifi 0000:00:14.3: 0x08001802 | isr2
[ 199.029435] iwlwifi 0000:00:14.3: 0x404001C0 | isr3
[ 199.029436] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 199.029437] iwlwifi 0000:00:14.3: 0x001E0177 | last cmd Id
[ 199.029438] iwlwifi 0000:00:14.3: 0x0001A83E | wait_event
[ 199.029439] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 199.029441] iwlwifi 0000:00:14.3: 0x00000820 | l2p_duration
[ 199.029442] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 199.029443] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 199.029444] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 199.029445] iwlwifi 0000:00:14.3: 0x08081425 | timestamp
[ 199.029446] iwlwifi 0000:00:14.3: 0x0000183C | flow_handler
[ 199.029592] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 199.029593] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 199.029594] iwlwifi 0000:00:14.3: 0x20000034 | NMI_INTERRUPT_WDG
[ 199.029595] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 199.029597] iwlwifi 0000:00:14.3: 0xC008885E | umac branchlink2
[ 199.029598] iwlwifi 0000:00:14.3: 0x80454D04 | umac interruptlink1
[ 199.029599] iwlwifi 0000:00:14.3: 0xC00842AC | umac interruptlink2
[ 199.029600] iwlwifi 0000:00:14.3: 0x00000400 | umac data1
[ 199.029601] iwlwifi 0000:00:14.3: 0xC00842AC | umac data2
[ 199.029602] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 199.029603] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 199.029604] iwlwifi 0000:00:14.3: 0x6BF1DF06 | umac minor
[ 199.029605] iwlwifi 0000:00:14.3: 0x000396CD | frame pointer
[ 199.029607] iwlwifi 0000:00:14.3: 0xC0886B5C | stack pointer
[ 199.029608] iwlwifi 0000:00:14.3: 0x001F010C | last host cmd
[ 199.029609] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 199.029630] iwlwifi 0000:00:14.3: Fseq Registers:
[ 199.029639] iwlwifi 0000:00:14.3: 0xD9691F0C | FSEQ_ERROR_CODE
[ 199.029647] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 199.029655] iwlwifi 0000:00:14.3: 0x7F5B52FF | FSEQ_CNVIO_INIT_VERSION
[ 199.029664] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 199.029672] iwlwifi 0000:00:14.3: 0x56769A21 | FSEQ_TOP_CONTENT_VERSION
[ 199.029680] iwlwifi 0000:00:14.3: 0x22DD5979 | FSEQ_ALIVE_TOKEN
[ 199.029689] iwlwifi 0000:00:14.3: 0xAF64419A | FSEQ_CNVI_ID
[ 199.029697] iwlwifi 0000:00:14.3: 0xCF84088E | FSEQ_CNVR_ID
[ 199.029705] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 199.029716] iwlwifi 0000:00:14.3: 0x00000201 | CNVR_AUX_MISC_CHIP
[ 199.029726] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 199.029767] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 199.029832] iwlwifi 0000:00:14.3: iwlwifi transaction failed, dumping registers
[ 199.029835] iwlwifi 0000:00:14.3: iwlwifi device config registers:
[ 199.030551] iwlwifi 0000:00:14.3: 00000000: a3708086 00100406 02800010 00800010 a441c004 00000000 00000000 00000000
[ 199.030554] iwlwifi 0000:00:14.3: 00000020: 00000000 00000000 00000000 42a48086 00000000 000000c8 00000000 000001ff
[ 199.030556] iwlwifi 0000:00:14.3: 00000040: 00928010 10000ec0 00100c10 00000000 00000000 00000000 00000000 00000000
[ 199.030557] iwlwifi 0000:00:14.3: 00000060: 00000000 00080812 00000405 00000000 00000000 00000000 00000000 00000000
[ 199.030559] iwlwifi 0000:00:14.3: 00000080: 800f0011 00002000 00003000 00000000 00000000 00000000 00000000 00000000
[ 199.030561] iwlwifi 0000:00:14.3: 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 199.030563] iwlwifi 0000:00:14.3: 000000c0: 00000000 00000000 c823d001 0d000008 00804005 00000000 00000000 00000000
[ 199.030565] iwlwifi 0000:00:14.3: 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 199.030567] iwlwifi 0000:00:14.3: 00000100: 14c00000 ff000000 000000ff 00462031 00000000 00002000 00000000 00000000
[ 199.030568] iwlwifi 0000:00:14.3: 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 199.030570] iwlwifi 0000:00:14.3: 00000140: 00000000 00000000 00000000 16410018 00000000 0001001e 00481e1f 00000000
[ 199.030572] iwlwifi 0000:00:14.3: iwlwifi device memory mapped registers:
[ 199.030697] iwlwifi 0000:00:14.3: 00000000: 18c89008 00000040 00000000 00000000 00000000 00000000 00000000 00000000
[ 199.030699] iwlwifi 0000:00:14.3: 00000020: 00000000 0c040005 00000312 d55555d5 d55555d5 d55555d5 80008040 041f0040
[ 199.030723] iwlwifi 0000:00:14.3: FW error in SYNC CMD SCAN_CFG_CMD
[ 199.030967] iwlwifi 0000:00:14.3: Firmware not running - cannot dump error
[ 199.423626] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 199.423992] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 199.423996] iwlwifi 0000:00:14.3: Status: 0x00000050, count: 6
[ 199.423999] iwlwifi 0000:00:14.3: Loaded firmware version: 46.6bf1df06.0
[ 199.424003] iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 199.424005] iwlwifi 0000:00:14.3: 0x00A022F1 | trm_hw_status0
[ 199.424008] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 199.424010] iwlwifi 0000:00:14.3: 0x004882DA | branchlink2
[ 199.424013] iwlwifi 0000:00:14.3: 0x0047932A | interruptlink1
[ 199.424015] iwlwifi 0000:00:14.3: 0x0000B0D0 | interruptlink2
[ 199.424018] iwlwifi 0000:00:14.3: 0x0001A83E | data1
[ 199.424020] iwlwifi 0000:00:14.3: 0x00001000 | data2
[ 199.424022] iwlwifi 0000:00:14.3: 0xF0000008 | data3
[ 199.424025] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 199.424027] iwlwifi 0000:00:14.3: 0x00039BE4 | tsf low
[ 199.424030] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 199.424032] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 199.424034] iwlwifi 0000:00:14.3: 0x00039BE4 | time gp2
[ 199.424037] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 199.424039] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 199.424042] iwlwifi 0000:00:14.3: 0x6BF1DF06 | uCode version minor
[ 199.424044] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 199.424046] iwlwifi 0000:00:14.3: 0x18C89008 | board version
[ 199.424049] iwlwifi 0000:00:14.3: 0x001D0177 | hcmd
[ 199.424051] iwlwifi 0000:00:14.3: 0x00122080 | isr0
[ 199.424053] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 199.424056] iwlwifi 0000:00:14.3: 0x08001802 | isr2
[ 199.424058] iwlwifi 0000:00:14.3: 0x404001C0 | isr3
[ 199.424060] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 199.424063] iwlwifi 0000:00:14.3: 0x001D0177 | last cmd Id
[ 199.424065] iwlwifi 0000:00:14.3: 0x0001A83E | wait_event
[ 199.424068] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 199.424070] iwlwifi 0000:00:14.3: 0x00000820 | l2p_duration
[ 199.424072] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 199.424075] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 199.424077] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 199.424079] iwlwifi 0000:00:14.3: 0x08081425 | timestamp
[ 199.424082] iwlwifi 0000:00:14.3: 0x0000183C | flow_handler
[ 199.424229] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 199.424232] iwlwifi 0000:00:14.3: Status: 0x00000050, count: 7
[ 199.424235] iwlwifi 0000:00:14.3: 0x20000034 | NMI_INTERRUPT_WDG
[ 199.424237] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 199.424240] iwlwifi 0000:00:14.3: 0xC008885E | umac branchlink2
[ 199.424242] iwlwifi 0000:00:14.3: 0x80454D04 | umac interruptlink1
[ 199.424244] iwlwifi 0000:00:14.3: 0xC00842AC | umac interruptlink2
[ 199.424247] iwlwifi 0000:00:14.3: 0x00000400 | umac data1
[ 199.424249] iwlwifi 0000:00:14.3: 0xC00842AC | umac data2
[ 199.424251] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 199.424254] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 199.424256] iwlwifi 0000:00:14.3: 0x6BF1DF06 | umac minor
[ 199.424258] iwlwifi 0000:00:14.3: 0x00039BCC | frame pointer
[ 199.424261] iwlwifi 0000:00:14.3: 0xC0886B5C | stack pointer
[ 199.424263] iwlwifi 0000:00:14.3: 0x001E010C | last host cmd
[ 199.424265] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 199.424284] iwlwifi 0000:00:14.3: Fseq Registers:
[ 199.424294] iwlwifi 0000:00:14.3: 0xD9691F0C | FSEQ_ERROR_CODE
[ 199.424304] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 199.424314] iwlwifi 0000:00:14.3: 0x7F5B52FF | FSEQ_CNVIO_INIT_VERSION
[ 199.424324] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 199.424334] iwlwifi 0000:00:14.3: 0x56769A21 | FSEQ_TOP_CONTENT_VERSION
[ 199.424344] iwlwifi 0000:00:14.3: 0x22DD5979 | FSEQ_ALIVE_TOKEN
[ 199.424353] iwlwifi 0000:00:14.3: 0xAF64419A | FSEQ_CNVI_ID
[ 199.424363] iwlwifi 0000:00:14.3: 0xCF84088E | FSEQ_CNVR_ID
[ 199.424373] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 199.424385] iwlwifi 0000:00:14.3: 0x00000201 | CNVR_AUX_MISC_CHIP
[ 199.424397] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 199.424439] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 199.424449] iwlwifi 0000:00:14.3: Firmware error during reconfiguration - reprobe!
[ 199.424542] iwlwifi 0000:00:14.3: FW error in SYNC CMD SCAN_CFG_CMD
