Manjaro Cinnamon won't do steam?
I installed Manjaro Cinnamon today. Honestly, I chose it because it looked pretty. I wanted to download steam. I downloaded it but I can't find how to actually run it. I'm a complete noob. I can't figure out how to load it. Can y'all help me?
Have you tried restarting? Sometimes things won't show up in the menu until after a restart.
How did you download steam? From the terminal, software centre (YAST if i remember correctly - which I probably dont)
or direct from the internet?
Did you actually complete the install of steam or just download the installer itself?
this may also be relevant
Did you use your package manager? The file on the steam website is a .deb package for Ubuntu. In Linux you don't install things from websites you use a package manager which pulls software from trusted repositories.
@Vandal85 YaST is for OpenSuse
Manjaro I thought has Steam out of the box. Goblook for it.
Here is some reading on how Manjaro/Arch handles software:
https://wiki.manjaro.org/index.php?title=Pacman_Overview
If all you want is the look of manjaro and are a novice then go for xbuntu, in 5 minitues i replicated the look of manjaro.
He is using cinnamon not the same DE
LOL thanks @lessershoe I knew I was wrong! Not the first time and it wont be the last either ;)
Here is a tuto to install "steam" it's for antergos but will work for Manjaro
Also please note that Manjaro Cup of linux comes preinstall with steam
(I have it install in a VM for practice)
http://www.cupoflinux.com/SBB/index.php/topic,2494.0.html
Welcome to linux Enjoy
Well. I think I'm just gonna install regular Manjaro since it supports Steam. Thanks for the help though.
