I've started using Manjaro; since well today and I have encountered an issue when booting.
I was messing around and pressed ctrl-alt-del, the screen went black (with a blinking underscore in the top right) and I cannot boot into the OS.
Upon rebooting I used ctrl-alt-f1 to see if the OS was giving any errors, all of list said things that started up is 'OK' however at the bottom of the screen it shows the following message:
"[drm:intel_uncore_check_errors [i915]] *error Unclaimed register before interrupt"
Have patience with me as I'm new to this distro and relatively new to linux
Upon fumbling around with different kernels, I managed to get a GUI up and running. The heart of the problem was a intel_vesa driver which I installed the same day of the problem.
Major derp; however if this happens to anyone else I would recommend login in as root (using the Ctrl-Alt-F2>F6) and then using the sudo mhwd-kernel command to install the latest or the 'most' stable kernel available.
I think a good practice (for me anyway) would be if you install a driver, restart the machine. I hadn't! Then when I randomly pressed Ctrl-Alt-Del the GUI restarted; and because of the wrong driver then crashed my machine.
Do you have xfce as Desktop Enviroment? If yes try On Xfce goto Settings>Window Manager Tweaks>Compositor and check "Synchronize drawing to the vertical blank".
