Hey everyone I’m looking to buy a replacement managed gigabit switch. I’m using a Linksys SRW2016. It works but it’s time for an upgrade. I’d like to spend about $200 or less. Any suggestions or recommendations are greatly appreciated.
12+ ports
fan-less or very quiet fan/s
web GUI that’s not ugly webview
rackmountable would be a plus
I have two tp-link jetstream switches, I can recommend them.
I just pulled up the 16 port variant and I think this is exactly what I'm looking for. Thank you!
There are 2 versions of the HP 1810-24G, one large one with fans and one smaller one (10 inch i think) with no fan. Ill be using it for years and if your look carefully you can find then dirtcheap! Even under 100 dollars.
