Making my ever first built computer
SO ME AND A FRIEND PUT TOGETHER A EVER FIRST BUILT COMPUTER IT WOULD BE USED GAMING LIKE CALL OF DUTY/BATTLEFIELD/FRY CRY/LOL and many more other games! and also be using this for homework and watching movies! AND WAS WONDER WHAT YOU GUYS THINK. SEE IF YOU GUYS CAN MAKE IT ANY BETTER MAKE ANY CHANGES TO MAKE IT BETTER MY BUDGET 750-840
Case -
http://www.amazon.com/gp/product/B005869A16/ref=ox_sc_act_title_4?ie=UTF...
  Motherboard -
 http://www.amazon.com/gp/product/B00GH9MZCY/ref=ox_sc_act_title_8?ie=UTF...
 CPU -
 http://www.amazon.com/gp/product/B00CO8TBOW/ref=ox_sc_act_title_9?ie=UTF...
 RAM -
 http://www.amazon.com/gp/product/B004CRSM4I/ref=ox_sc_act_title_7?ie=UTF...\
 SSD -
http://www.amazon.com/gp/product/B00BQ4F9ZA/ref=ox_sc_act_title_6?ie=UTF...
 Hard Drive -
 http://www.amazon.com/gp/product/B005T3GRNW/ref=ox_sc_act_title_5?ie=UTF...
 Power Supply -
http://www.amazon.com/gp/product/B00H33SFJU/ref=ox_sc_act_title_3?ie=UTF...
 Graphic Card -
http://www.amazon.com/gp/product/B00IDG3NDY/ref=ox_sc_act_title_2?ie=UTF...
THANKS FOR THE HELP!
I'm surprised by your choice of graphics card.  For 800 I'm pretty sure you can get a much better GPU by careful shopping in other areas, and it'll make a big difference in the games you listed.
Bit wimpy on the GPU.  Up that to an R9 270 or GTX 760.
Here are some ideas.
http://pcpartpicker.com/p/KPyTzy
YO Reservation Station WOULD YOU SAY YOUR BUILT WOULD GO EPIC GAMING AND MOVIES/HW!?!?!
I SUCK WITH COMPUTER SO YEE LMFAOOO
Dude, chill on the caps
https://teksyndicate.com/forum/build-pc/my-first-built-comp-check-it-out/180467
Why make two
Anyway here is what i was going to recomend
Intel: http://pcpartpicker.com/p/ppgxbv
AMD: http://pcpartpicker.com/p/6f7BhM
The intel build is $30 over because i have added a cpu cooler as you have a unlocked chip so i presume you will overclock in the near future.
Either of these builds would be fine.
Also if you want to buy all parts from amazon you can override the price picker however it will cost more as it list's the cheapest parts.
You might want to get the SSD in a future upgrade. For now you would be better off investing that $70 in a better GPU like a r9 270x. Your also in a price range where you should at least consider the fx 8350.
so basically this
Basically that.
ALRIGHT LET GOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO LMFAOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
wait so when i want to upgrade i can take out the AMD AND replace it for a intel will that mess anything up?
No, you will also need to get a new motherboard. You will also probably need to reinstall windows.
wow gay can you link me to a good new motherboard and intel and anything else to put into this later on when i plan to upgrade
you could just save a bit of cash and buy the intel build i made you
however if you cant then i suggest the amd build as it is quality.
With either build the only upgrades you would need to do in maybe the next 4 years is:
Ass more storage(another SSD and a 1TB drive)
Buy a second r9 280 and run in crossfire or just simply sell it and upgrade with the money you earnt and saved, to like a r9 290x or a geforce 780
Add more RAM (unnecessary if your only gaming, only really needed if you are going to start video editing and rendering.
The case if you want to but the one listed is fine tho
The psu to something like a 750w 80+ gold modular if you want modular cable and need more watts
And the cpu cooler (unnecessary if you are mild oc'ing but if you plan to go further get something better)
