Hey, first of all, I want to say thank you to everyone that reads this.
I want to switch to Linux but I have a fair bit of games that I can’t run on Linux ex: Forza Horizon 4, Sea of Thieves, Dead by Daylight, etc. What I want to do is to run the games that work nativley on Linux or works with Proton or Lutris on Linux and for the games that don’t work on Linux at all use a windows 10 VM. From what I understand I need to passthrough my GPU. But from what I saw I can’t use the GPU for Host even when I am not running my VM.
Also, some resources on virtualization would be appreciated.
P.S.: I was planning to use Manjaro but I am not fixed on that.
Thank you for your answer, but I still want to know if while I don’t have the VM turned on I can use my primary GPU on the Host? I don’t have any USB PCI-E card but I was wondering if using a dedicated ethernet card for my VM will help. Also, I was wandering if there will be any problems if I use my iGPU or shoud I go with a secondary dedicated GPU.
If your iGPU is good enough for the games you play, you can use it and pass the dedicated one through. Since I don’t think that this is the case, You should go with two cards. For Linux I suggest getting a (used) 470/480/570/580 since they are quite enough for most games at 1080p. And cheap AF.
Sounds like a doable plan. I suggest disabling the iGPU in that case. While it is possible to utilize it, it’s more pain getting it working correctly than it’s worth. At least from my experience. But maybe someone more proficient with that can chime in.
Does your motherboard have separate IOMMU settings to enable? If not, ACS override might be a consideration. Let me check if I can find the article about that…
Maybe you can try update or downgrade bios or use another pci-e slot if possible? My gigabyte messed my iommu groups when i updated bios so back to old one.
