Hi guys well i just need some input on my selection. Im planing on upgradeing my pc here are my specs now.
my specs
750w rosewell psu
6870 xfx 1 gb
1600mhz 4x4gb ripjaws gskill
m4a88t-v evo asus motherboard
955 be 3.2ghz @ 3.8
antec 620 (modded- clear tubes and added swifttech rez and ek coolant)
2x 320 hdd raid0 os
1x 500gb
1x 360gb
windows 7 pro
30" lcd 1080p (main)
22" 1600x1050
razer mouse
i do a lot of dvd burning and have a dns server runing in back ground also i have ocd with lag in games. Im planing on gettin a ssd in the future maby 2 months so i can worry about high end hardware. I will need a new keyboard since my good one broke. I will need a backlit keyboard also i will be ocing my ram to 1866 so here is wat I was thinking and ill explain why on each
amd 8350 4ghz $190
i require a lot of power because of the video converting and dns server and i do a lot with vmware
sabertooth gen3 motherboard $200
I like this board because its the only am3+ board with pcie 3.0 so changeing the board could be a option if needed I just like the future proof.
xfx 7950 3gb $330
I like the 3gb since I will be designing games with unity 3d and the power is nice and can be overclocked to run just as fast as the 7970.
cosiar h100i $109
The stock cooler is not good enuf to keep the cpu cool and I plan on overclocking to around 4.5ghz also I am planing on getting a full wc custom loop I will be changeing out the h100i with it or I can get it now if we change things up.
aerocool xpredator-x3 $132
I like this case cause my wife wants a white case and I can put a 2x120 rad in it also the cable management is perfect but might be willing to change.
hyper x cooler $22
for cooling ram
need a key board
here are all links
http://www.xoxide.com/aerocool-xpredator-x3case-whiteedition.html case
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4904561&CatId=7339 cpu
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7889689 mobo
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7413643 cooler
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7017867&CatId=496 memory cooler
