Major Help
Hello i just did a fresh install of windows 8 pro
1) but its giving me the message Activate windows now i did research used all the different methods its still showing the message what should i do. I also get a message saying windows detected hard disk problems ive seen that message before.
2) i tried install avast premier it said my trial period is over on my new install ?? it expired on my windows 7 why does this occur
3) Everytime i try use a cyberghost vpn it says script error when intergrated with avast ?
4) Everytime i go on security website for software and things firefox takes a long to to get to the website. I think my browser has been hijacked on the new install and previous verision.
5) I also did some research and i have a feeling its a host intrusion or network instrusion whats a good ids or hips to put in place. When i use some sites that have captcha's the capatchs is personalised eg my name, or something firmiliar to me. Am not sure if its a mitm ive used malwarebytes, adwcleaner and avast on my windows 7 when i using but all scans came up clean.
6) I am not sure if its a dns leak what are some of the systems i can put in place to help
7) when i used to go on twitter the time on the timeline would changes a few seconds later eg if the post was 2m ago a few second later it will says 4hr ago  any ideas
8) i constanlly get this feeling my laptop is being snooped but when i use avast to do a network scan it comes up clean.
9) i would like to move to linux but i have no idea how to make the switch or get the program
is there any software andd actions i can take to figure out my problems thanks
ANY1?
