Yea the first option, like DerKrieger said, you can always get a decent external hdd. I have a 256gb in my macbook pro, just want all your main programs, the rest can be transferred over.
And 5400rpm.... smh apple. Guess they can't cool a 7200.
Honestly you could save yourself some money and go for an i5, 8gb of Ram and 256GB flash storage if you are just doing music production. You could get a similarly specd Macbook Air and that would give you a few more hours of battery life and save yourself a few more pennies, although the Macbook Pro I/O and display is really nice. I have no problem running Windows and BSD in VM's whilst using remote desktop to control servers as well as having about 4 or 5 basic apps open on 8GB of ram and an i5.
You might tear your hair out if you buy a 1k laptop that has a lagging 5400rpm hard drive. I work with Macs and it takes about 3 to 4 times as long to complete tasks and to boot up on machines that have 5400rpm hdd's compared to the flash storage. FYI, the 256GB flash storage is quicker than the 128GB variety.
If you don't mind a little DIY, I have a non-retina macbook pro that has had the hdd replaced with an ssd, the ram upgraded to 8gb and the superdrive replaced with a 1tb hdd
I'd do the maths to work out if its worth the price and time over getting the pre-built retina model
Only possible issue would be the screen resolution, but personally, for a 13 inch laptop, i'm fine with the 1280x800 resolution.
I bought the non retina macbook a few weeks ago off of eBay for $550, the baseline model though. But for $300 more I will be upgrading to a 500GB ssd and 16 GB of ram. And the screen is good enough for a little web developer as myself. But the only reason to get the retina is for better battery, slightly beefier processor and Thunderbolt 2. And the screen is beautiful on both models. Just be prepared to run safari because chrome will destroy your battery life.
Anything Apple + music will eat RAM. I use Logic Pro X for some of my stuff and even bouncing a 10 minute track will freeze my Laptop. I have an i7, but the RAM is a must have.
+1 for the 1st option. More RAM is the best option. The smaller SSD option can be remedied with an external thunderbolt drive. Also get an adapter for Thunderbolt to HDMI for a larger second external monitor.
I think you need a jump to conclusions mat - I'm talking about Audio hardware and software. The comp hardware is in the post and can go without saying.
Plus, I wasn't asking you, so why guess and act like you know what you're talking about?
