So it seems it rates well across the net but has anyone here used it? Anyone recommend it or say no way to it?
I know its reliable, I knew someone who has used it before.
Personally, I can't stand something that small though.
They had another mouse at the store that was Logitech wireless and was larger but I don't remember the model # or whatever. Is it basically that anything wireless made by Logitech is good? From what I see on the net that is the case. The funny thing is the only Logitech product I had which was the G300 died just after 1 year and also had issues with the logo wearing off of it.
logitech are like the toyota camery's on the mice world.
as in, you know what you're getting usually. Nothing fancy but cheap work horses. Also works on all OS; which is nice.
I ended up getting the M187 mini wireless mouse by Logitech as I realized smaller was better for where I was going to be using this. Thanks for your input on both posts I made in this section of the message boards and it definitely helped me in my decision making in regards to both items.
You're welcome
