Hi, when I have the drivers installed for the Lycosa I cant use the touch pad, but when the drivers are uninstalled the touch pad works, does anyone know how to fix it and im running Vista 64-bit
Did you restart?
Unplug, plug. :)
or
Getacyborg...
i have restarted and i have tried unpluging and pluging it back in
hmmm i think i can say Vista 64 bit is your problem not sure hmmmm.......Strange?
maybe you got a faulty one? try talking to razer about it maybe they will send you a new one or at least tell you how to fix it. somestimes they will get you a new driver if thats the problem
