Lutris is not magic
Is buggy, cluttery and now its installing steam
My eyes are bleeding.
How is this easier than wine?
i AM online!
My version doesn’t need steam. But it’s not like i get a choice.
Scripts documentation is hell id@$#%@
Bro, chill if you don’t like it, don;t use it. Tho you could manually add games with “add” button. Also CS:GO req. steam, unless pirated edition…
You’ve missed some critical steps in setting up and using lutris, and also your missing the point of lutris which its not mean to replace WINE, its a launcher that allows the use of wine and also anything else.
It provides a easy to use GUI interface for configuration with script support. However you’ve completely miss-stepped here, its well documented also, perhaps look at some youtube videos showing off and explaining the use of Lutris first?!
i am going kvm route for now as weekend is coming.
But the steam not downloading (from lutris {by wine}) is real though
Does steam install regularly with wine?
Terminal output?
Error logs?
Distro?
Wine version?
You’re probably missing some dependency, but we really need more information.
