In my pursuit of VFIO Windows VM gaming. I’m trying to figure out my hardware topography. In doing so, trying to understand why my lstopo produced image is not showing properly or perhaps, not as expected or mirrored what the live environment produced.
Output produced booted to NVME1n1 (Fedora KDE spin):
My system specs and known layout is:
CPU: Threadripper 3960x - 24 cores & 48 Threads
RAM: 32GB x 4 @3600MHz = 128GB
Gigabyte TRX40 Aorus Master
GPU1: Asus GeForce 1080 Turbo - PCI 21:00:0
GPU2: Asus ROG Strix GeForce 3090 - PCI 4a:00:0 (Passthrough)
nvme0n1 - PCI 01:00:0 (Passthrough)
nvme1n1 - PCI 02:00:0 (Host: Fedora)
On-board Intel NIC - PCI 43:00:0 (Passthrough)
Now I should stated that the VM is running, rather nicely, I’m was able to follow the Fedora 33/34 guide here on L1, almost to the tee, but I would like to squeeze as much performance out of the VM as possible.
Yeah, I ran: virsh capabilities | grep “cpu id” to get the thread pairs for pinning, but I’d rather like to understand the image to better organise the hardware for best performance. Example: organise the CPU pinning with the fastest path to the appropriate PCI devices/slots.
When viewing the graphical output, press “f” to toggle collapsing.
Note that it lists the commands in the cli when run
Keyboard shortcuts:
Zooming, scrolling and closing:
Zoom-in or out ...................... + -
Reset scale to default .............. 1
Try to fit scale to window .......... F
Resize window to the drawing ........ r
Toggle auto-resizing of the window .. R
Scroll vertically ................... Up Down PageUp PageDown
Scroll horizontally ................. Left Right Ctrl+PageUp/Down
Scroll to the top-left corner ....... Home
Scroll to the bottom-right corner ... End
Show this help ...................... h H ?
Exit ................................ q Q Esc
Configuration tweaks:
Toggle factorizing or collapsing .... f
Switch display mode for indexes ..... i
Toggle displaying of object text .... t
Toggle displaying of obj attributes . a
Toggle color for disallowed objects . d
Toggle color for binding objects .... b
Toggle displaying of the legend ..... l
Export to file with current config .. E
An unrelated but good thing to know is that the graphical output and the CLI output lstopo --of console have opposite defaults for physical or logical indexes, because of historical compatibility bullshit. Graphical defaults to physical -p and cli defaults to logical -l
Really now? Wow… Why is this not standard? Thank you Log for stating that. I swear I’ve looked at all the switches and didn’t think it was sized wrong, interesting…
