Hello, I run a small NAS with an ASRock J3355B-ITX and 4 SATA drives. I have used a consumer PCI-E to SATA card for a while, but recently one of it’s ports became flaky, so I decided to update to a proper HBA.
I bought an LSI Logic sas3444e and finally got around to using it in my server. I plugged in all the drives, booted into my debian install, ran lsblk, and nothing. So, I do lspci, no mention of the card. I enabled all CSM options, still nothing, not even the PCI option rom screen shows up. I even decided to boot into uefi shell and list all devices though pci and it’s still not there. The card itself has it’s LEDs on and one of the LEDs on the back side blinking slowly.
I googled a bit and found that these cards don’t seem to play with UEFI very well, so I am currently arranging a legacy bios computer to plug it in and see. I also apparently need to flash it into IT mode to just use it as a PCI-E to SATA bridge. Which I have trouble finding online, as “sas3444e IT firmware” doesn’t return anything of use, just people mentioning they did it, but not files or instructions… I found stuff for the “SAS9217” so I assume the process would be similar, but any links for my card that I did find are dead. And there is also no guarantee that it will work in my UEFI system after flashing.
So, I am looking for some advice on what to do, should I just cut my losses and buy something different? Or is there hope that if I flash this card correctly in the older system that it would work fine as a simple sata bridge. And maybe someone has some pointers on where and which firmware I should obtain and what the correct flashing process for this particular card is.
Thank you.
