Hi,
https://www.liqid.com/products/composable-storage/element-lqd4500-pcie-aic-ssd
Does anyone have a thoughts on the effectiveness of a drive like this as virtual memory?
Thanks
Mark
Hi,
Thanks
Mark
if you want to use this as your swap partition
your ram will have to be small enough that you will always over use it, but using a SSD like device as swap will burn out the life of the memory cells.
since it didn’t post a price id imagine it’s more expensive then buying more RAM.
The objective is to avoid buying very large amounts of ram for specific seismic processing jobs jobs (up to 2tb of RAM).
