Hello, i want to build a low to mid grade PC that is around SGD$850 give or take.
Im going to assume that you are going to use this as a gaming PC, and with that in mind I would say that, that GPU is going to bottleneck the CPU quite some..
If you want it to be optimised for gaming I would get a good AMD processor and spend alot more on the GPU. you should get some faster memory with CL9, either 1600mhz ot 1866mhz.
in summory, downgrade the CPU and upgrade the GPU..
