I am new to the home lab world, I’m looking for a lower powered homelab under 10w at idle, the lower the better, electricity is expensive where I live. I am looking to run 2 x hdds in mirror & 2 x m2s to begin with the ability to expand further as required.
Main goals is to
backup data like photos, documents etc. (Hdd)
low powered at idle reaching high c states, however has the power to run vms / dockers etc.
Under 600 dollars (happy to self build)
Can use an nvidia graphics card for machine learning (nice to have)
The RPi isn’t great, at least go for Rockchip if you’re going for cheap ARM SoCs. ODROID-H4 PLUS – ODROID is in the same ballpark with much less headache and noticable better performance.
If you’re only goal is a backup-server, then build a backup-server. Mine’s an odroid hc4 with 2x hdds. Don’t keep it up 24x7, power it on when you run a backup.
If you need a NAS, it’s still doable as a NAS, but the CPU is very limiting. Get an odroid h3 or h4+ for that, with 2x or 4x sata ssds. And there’s no way you’d be running an nvidia GPU paired with a box that does less than 10W (not to mention that the GPU would suck up at least 3 or 4x at idle than the whole build, you’d need an external PSU to power it).
The rock chips are only better on paper. Their longevity suffers. Ive literally done this before. Alot. Their power supplies die and sometimes kill the board
Just go with a known quantity and that which has the best support. Im trying to save this guy a headache
Plus the pi 5 if you watched the video I provided has true nvme hooked up to pcie. Its a good platform for a nas
Odroid are fairly on par with the rpi4 though so they are a good budget option but as someone new to the game. I highly suggest something with extremely wide support
What are you talking about? Rockchip creates SoCs not PSUs? =)
The RPi or BCM2712 to be more correct sports a 1x 2.0 PCIe line, the “old” RK3399 sports better connectivity and works great.
I’m afraid that’s not possible with any dedicated GPU and using HDDs.
Intel N305 is the best chance you have at achieving this in my opinion.
600$ with or without drives? With drives is impossible, depending on how much storage you’re looking to get.
Also there’s no way to get into this system at 600$ with a dedicated GPU that’s powerful enough to get some ML going, even at a slower pace.
Also you need to get some research done before asking. Not just because it’s good practice to try and understand a problem on their own first, but because someone might say some dumb shit and you’ll never be able to even question it.
Well, The Asustor Flashstor 6 gen 1 has an idle power draw of 15W and maximum power draw of 25W when fully populated with six slots. That is $449 for a base unit that takes you to 90% of where you want to be. SSD drives are a little pricey right now, but a $700 budget could get you started on a single SSD 4TB setup, and a $600 budget nets you a neat 2TB setup. This would probably require a secondary computer to do the homelabbing on though - but that does not have to be an always on server, might as well just be your regular desktop for instance.
As for an x86 based DIY solution the lowest you could expect is around 35W-40W idle, disks and all.
$600 will not even buy you a 4070, which is now the bare minimum for any productive AI work. If you just want to dabble in AI, you can get pretty far on integrated circuitry alone, and AWS can cover a lot of the rest.
