I hope someone, can help me figure it out.
For some reason, my MSI 1080 SeaHawk is limiting itself to 0.90-0.92V.
This limits me to ~1700MHz, far from the 2XXXMHz other card can do.
This is with a Core voltage at 100% and Power limit at 105%(Max limit on stock firmware).
I’ve observed it over 1V but only for a split second.
The temperature seems to be in check GPU temp under 60 at full load(Furmark).
I don’t know about the VRM, but they do have there own dedicated cooler.
I tried flashing a Founders Edition firmware, and while the default clock speed is lower, the Power limit can be set at 120%.
This allowed 0.95V, but thats still far from what I need for higher clocks.
And now I’m out of ideas…
Edit: Forgot that I also tried putting it in OC mode, using MSI’s utility.
And it made no to little difference.
Edit 2: It seems the driver is detecting Furmark, and limiting the performance, to keep me “safe” I guess…
It’s not the first time, that furmark has been targeted like that. CoughingAMDdriversCoughing…
Short your shunts with Liquid Metal… That’s how to get around it at the cost of insane power usage. This fools the driver into thinking it’s using less power than the card is actually pulling.
It’s an overclock card… He said the VRMs are sufficiently cooled and it’s all under water. Just use nail polish on SMD components and just be careful to remove the liquid metal on the shunts once benchmarks are done.
If you disagree with the power limits, get around them.
So how is using liquid metal any different from a shunt resistor? Gallium has a resistivity of 1.4×10-7 m Ω. As an electrical engineer it seems safer to use a shunt resistor opposed liquid metal
It is. And you’re not wrong. People just use it on top of pre-existing 50 ohm shunts to get their overclocks in then remove it once the benchmarks are done.
Adding more liquid metal will be more effective, but you begin greatly increasing risk of (1) LM dripping and shorting other components, thereby killing the card
I think its reasonable to assume OP wants a stable OC not records
he’s only looking for a few hundred extra megahertz
Then don’t use Furmark. Run a Unity game with Vsync off that uses AVX instructions. Any modern Unity game is extremely stressful on the GPU with Vsync off.
Heck, Unigine Superposition looped by using the Game mode -> Cinematic mode trick should do too. The driver would think Superposition is a game.
I use it for CPU stability too. Don’t question my methods. I’ve had Prime95 AVX pass, but a AVX instruction Unity game BSOD after confirming Prime stability.
Assuming this is the Sea Hawk with the AIO and not the one that is just has an EK block on it, then they are not under water and have meh cooling. The Sea Hawk is just a Corsair 120 AIO slapped on the GPU. The memory and VRMs all just use the standard blower cooler. While this should be sufficient, you don’t wanna go hog wild.
Also, a 1080 will boost to 1900Mhz even sub 1V. Overall power limit is your biggest limiting factor.
Also GPU Boost is extremely sensitive to temperature. Every 5 degrees can cut your boost by ~50Mhz or more.
I don’t see too big of an issue with it though. Furmark is pretty pointless IMO. Games are what matters and you can manually OC. You should easily be able to hit 2000Mhz at stock power limits.
My waifu’s 1080 will boost to over 2000Mhz by itself if given 105%. With basic tweaking 2100 isn’t much issue
OP had no issue with temperature, but if you’re concerned about the rest of the board, then yes, the AIO Sea Hawk is not 100% full coverage if you were technical about the true details.
Edit: Yes, Games and Unigine Synthetics sound more reasonable for OC targets.
