Low power, high performance PC
Hi,
First, thanks for your help.
I want to set up a PC that is on 24/7 and I want to use Rust Desk to remotely connect to it from my iPad or as a possibility to download stuff to it faster as my network connection is a lot faster where it will be placed. As it will be always running I want it to be using not to much power (Wattage) but still would like to have the best hardware possible. So my limiting factor is the power and my budget.
I would like to stay below a total of 65W of power. I guess most or even all Desktops don’t work.
65W is what most Laptops use and I would also be willing to remove batteries
So
My request
  • <65W
  • <$400
  • run Windows 11
What is the best I can get?
Getting a little dirty is ok. So adding RAM or an SSD is totally doable.
Buying used is the way to go :slight_smile:
I was mostly looking at mini PCs from HP and Dell but I am not fixed in that regard.
Replayability is not a factor, if it crashes i’ll just reboot it again, no harm done.
https://www.lenovo.com/us/outletus/en/p/laptops/thinkpad/thinkpadl/thinkpad-l14-gen-3-(14-inch-amd)/21c6x01200 ?
Lenovo X70 tiny could also work.
The idea of a mini-pc is not bad for your use. For example an ASRock Deskmini x300 with an Athlon 3000G via Newegg would be $250, add Storage and RAM to taste, easily below budget.
Another idea: Odroid H4 Plus and ITX-kit is $155, which also has the option to hook up 4 SATA-drives and turn this thing into a NAS.
I have an H3 serving in that role, and plan to do this with the H4 later this year.
