I currently use a dual Xeon setup for my TrueNAS box, which is wicked overkill.
I’d really like to find a setup that has lots of PCIe lanes to support several NVMe drives, but that is low power and heat. The only App/Container I run on the box is Nextcloud. I have a 3U chassis with high volume fans, but I’d really like to keep the heat down so they don’t have to spin up fast enough to be audible.
Are there any CPUs/SoCs that meet these criteria? Or are the only CPUs that support more than the standard 20ish PCIe lanes the more powerful CPUs?
In general, more electronics means more power consumption and as a result more heat. If you look hard you’ll be able to spot sweet spots.
You mention your desire to connect and run multiple nvme drives. How many are you thinking about?
Current gen consumer motherboards are not a bad choice from a performance/power consumption/cost point of view. They can connect 3-4 m.2 drives ootb. Using PCIe extention cards you may be able to connect >10 nvme drives to a consumer mobo, but obviously, they won’t be all connecting with 4 nvme lanes directly to the CPU. Also, that is most likely not necessary for optimal performance. However, its unclear if this is the best course of action.
If you are really looking for a system with >24/28 PCIe lane connectivity to the CPU you’ll be looking at HEDT, work station, server hardware. Unless you’re considering older generations they’ll be expensive. Power consumption sweet spots can be found in the XeonW range of CPUs.
Considering what seems to be a modest use case (“The only App/Container I run on the box is Nextcloud”), maybe hw that is custom build for this use case is ideal? Check out the ASUSTOR Flashstor line of products which allow connecting up to 12 nvme drives to an appliance, which is low power, quiet and otherwise modest in capabilities.
On AMD, 12 core Threadripper Pro is as good as you can get in the prosumer market. 8 core EPYC is as close as you can get in the server market. (Epyc is more efficient)
AMD in general is more efficent than Xeon Scalable right now.
