This is a consolidation effort as I've got 3 separate PC's with these storage drives dispersed among them and sadly I need them all on atm for access. Hurting my electricity bill since they're all gaming PC's...
The cost isn't too much of a factor. At the very least I'm going for a platinum PSU. I don't think there's anything more efficient than that?
I need a case/mobo combo that holds 6+ sata drives while still being as compact as possible (8+ would be even better). Style/aesthetics are desirable but not necessary. Hot swap is highly desirable or at the very least tool-less.
Everything else I can sort out myself. Thinking AMD, maybe APU if the TDP is low. Definitely looking for the lowest possible power rating overall as this thing will be on 24/7.
Mostly wondering if there's anything special I should be looking for? I'm looking for the -lowest- power utilization possible. Maybe the problem is all my old HDD's? What are the lowest power high capacity storage options ~3-6TB+ ?
