So I have one of those cheapo USB 2.0 HDMI capture devices that actually are close to the lowest latency you can get out of a USB capture device. There’s a few better options but they cost 10 times more.
Anyway, after configuring it correctly (need to set it to BRG3) it performed pretty well as a preview screen in OBS. The trouble is, it seems to stretch 4:3 resolutions to 16:9 and I don’t see how to fix this through OBS.
Are there other options that might be able to change the aspect ratio? gstreamer? I’m curious about them not just for the aspect ratio change but also because OBS isn’t exactly how I want to use this. I’d rather be able to just pop open a preview window from the command line ready to go.
