I was just curious if anyone else has run into the issue in bf4 where your frames drop below 60 whether or not you lower the settings. Note Vsync is not on. I understand it may be my proc bottlenecking my gpu but i find it weird it would bottleneck so much. Usage stays around 60-80% in bf4.
I have an fx-8350 at 4.82Ghz
16gb of ram
crucial mx100 sdd
Gtx980 @1528Mhz
Hello bmin2709,
I see that you have your system very well overclocked. I remember a video by jayztwocents, another tech youtuber, who said he had to lower some of the overclocks in some games because he was getting a lot of inconsistency, as you are experiencing, with framerates. His was with the GTX 980 as well, but a different processor (i7 5960X). Things might not be syncing up very well and causing reliability and stability issues during games. I would suggest downclocking, in small increments, either your GPU or CPU and testing each increment to see if the usage becomes stable and framerates don't dip as much.
- EWS
EDIT: He also had his i7 5960X and GTX 980 highly overclocked as well.
