Low End Gaming PC
The most GPU intensive game I'll play is probably COD4....
  • I dont care about playing on ultra settings
  • As long as I can play with no lag I'd be good to go
  • I just want something that can handle one monitor (probably a 27" 1080p monitor)
  • Really low end gaming (minecraft,LoL,DCUO)
  • Youtube 1080p streaming...
I think that's about it. Thanks for all the feedback!
[img]http://i46.tinypic.com/ehzvvo.png[/img]
AMD - http://pcpartpicker.com/p/nduE
OR
Intel - http://pcpartpicker.com/p/ndxW
The latter as far as I can see. More RAM, better PSU. I would never use the powersupply that comes with a 56$ case.
What? I must of posted the wrong links earlier... check them again please, I put a picture on the post too so you dont have to go to the links.
Second one fur sure
What if I just want to be able to play low end games at medium/low settings? I dont care about "ultra" settings, etc. is the extra $70+ worth it to build the intel system?
build the Amd rig without gpu and in a few months you use that $120 you saved to over the intel rig to buy a mid range gpu. no reason to buy a gpu if you dont need it right now.
Thanks for the response, that's exactly what I was thinking of doing :D thanks for all the input guys!!
