Hello there.
I need you help in troubleshooting my laptop. I will try to be as brief but as precise as possible.
THE PATIENT: Dell XPS 15 9500
- i7 10750H
- GTX 1650Ti 4GB
- 2x16GB DDR4
- 2x1TB SSDs (one aftermarket)
- FHD IPS matte non-touch 16:10 screen
- Running Windows 10 Pro + Ubuntu 22.04 LTS in dual-boot (one on each SSD)
- Up to date drivers and firmware as provided by Dell tools in Windows
THE USE CASES
- Coding
- Computation for physics, especially gravitational waves and astrophysical population analyses
- Music production
- Photo editing
- Some gaming on the side when I have time (very rarely, then)
THE SYMPTOMS
Random reboots in Windows 10 while using it (briefly shows the “Restarting/Shutting down” Windows screen)
Shutdowns after boot in Windows 10 and sometimes RE mode is triggered at next boot
Some coloured stripes and artifacts on the screen (hasn’t been happening for some weeks, happened especially in Windows, in IDLE, but sometimes in Ubuntu too)
Frequent Windows Blue Screens with different error codes
Black screens in Ubuntu while using it, especially in IDLE or light use
Sometimes wi-fi or Bluetooth do not show up in Windows, like if the wireless card drivers weren’ t loaded up correctly, malfunctioned or the hardware module itself stopped working. One or two system reboots make it work again.
Sometimes it stops charging while in Windows. More rarely it doesn’ t charge while turned off (very rare). I only use the original USB-C 130W charger provided by Dell to charge it
Sometimes gets stuck in GRUB “select the OS” screen. I cannot load any OS, neither can I move the cursor when it happens. Hard reboot is needed when it happens
THE CLINICAL HYSTORY OF THE PATIENT
- Battery changed within one week from purchase due to poor battery life from the get go
- Screen changed 2/3 times due to damage to the panel, likely caused by pressure points in the backpack
- Palmrest changed 3/4 times, always when other components were already been serviced
- Motherboard changed 2 times. One time after the laptop completely stopped charging (unlike now that charging stops only sometimes and is fixed after some reboots)
Note: all the components were serviced by authorized Dell technicians under Pro Support on-site 4-year warranty. Warranty is now expired (was no longer extendable)
THE TESTS
- Run 5 h of Memtest86+ full test in loop. No memory errors at the time
- Run 3 h of Uningine Heave, and some runs of 3D Mark in Windows: no crashes or coloured lines on screen
- Run 2 h of Cinebench R24 on loop: no crashes
I wanted to change this computer only when entering a PhD program or a new job, knowing the actual needs I will have at the time and having the first salaries to spend on the device. If I were to change it now, I will have less liquidity and I will only be able to guess my future needs.
Hence, before upgrading to a new device, I wanted to extend the life of this still decent (on paper…) XPS, and I therefore want to do some troubleshooting to see if there’s any way to save this laptop or mitigate the issues.
I’m currently using this as my main device, and I have a couple of projects I’m actively work on, so I’d really prefer not to have to wipe the device.
Thank you very much for your patience and help
