AM4 is effectively “dead” and W-21**/W-22** series uses very old tech by now so it’s more or less dead too. Both also lacks CPU features/instructions that are nice/nice to have for newer builds. I would also like to remind you that TrueNAS is primarily for using it as a NAS, you can do virtualization but it’s not ideal and given discussions on the forums quirky at best. Given your generic description of usage on your you’re likely better off using a generic distro such as FreeBSD, Debian, Alpine or whatever you prefer.
Gigabyte B760M DS3H doesn’t do IPMI at all, I’d also like to highlight that IPMI is quite expensive given the value for a homeserver especially on a fairly tight budget. It’s quite rare that you’re in a situation where your doesn’t boot at all and in that case it may very well need physical access anyway.
Gigabyte’s “workstation/server” boards in general seems to be terrible and I would advice you to look at something else.
Sagittarius only supports mATX which basically limits your choices on the AM5 side to ASRock boards which have issues and slow BIOS updates.
Given your budget I would advice you to look at something like this which would give you a better bang for the buck ratio and “fix” many issues.
General advices, get a 8 layer PCB on the AM5 platform, they usually fare batter in terms of stability and especially if you want to populate 4 DIMMS. Intel or Broacom NICs, it’ll save you a lot of headache further down the line.
Since you don’t list country it’s hard to give advice but from .de …
Motherboard:
ASUS ROG Strix B650E-E - ~260 EUR (amazon.de)
Decent board, good PCI-E slot layout (for HBAs, videocards etc), Intel NIC, supports ECC however it’s ATX and no IPMI but does have frequent BIOS updates.
Memory:
Micron MTC10F1084S1RC56BR - DDR5-5600 16Gb ~125 EUR / stick (grab 2x)
Case:
Fractal Design Define R5 (~125 EUR)
It’s not huge, good design overall and silent. Comes with 8 trays for HDDs although not hot swap but easy access and it’s a home server so it’s not really an issue.
CPU: ~220 EUR (or 60-70-ish more in total if you want to for the 9*** series)
AMD Ryzen 7 7700 - Decent CPU, 65W, 8 cores, stock cooler works good enough so no need to get an additional. Supports AVX512 which is nice for newer applications. 9000 series is a bit more efficient but pricing is still high and you need an additional cooler so it’s hard to justify unless you have very specific requirements.
HBA: (~40 EUR to ~150+ depending on choice)
A decent ASM1166 will do fine for spinning rust, you have 4 SATA connections on the board and something like this adds 6 more. GLOTRENDS SA3026 6 Ports PCIe X4 SATA Erweiterungskarte, inklusive SATA Kabel und 1:5 SATA Splitter Stromkabel, Kompatibel mit Windows,Linux,Mac OS,NAS: Amazon.de: Computer & Zubehör
You may need to update the firmware however, you can go with a LSI HBA but it’s usually overkill and adds additional costs (SFF cabling), power consumption. If you decide to go that route at least for the the SAS3*** series now newer as older are legacy (EoL) and have some quirks that you’d want to avoid if possible.
PSU: (Probably around the 100-200 EUR mark)
Something that at least supports ATX 3.0, modular is nice but not a requirement but as Exard3k mention you probably want to have a look at efficiency which doesn’t necessarily mean that it needs to be a Titanium rated on however…
Edit:
As you can see costs ramp up quite fast, you’re looking at roughly 750-800 EUR-ish without any storage.
