Losing OC on sleep
I'm losing my overclock on my FX-8320 when my computer goes to sleep. It's at 4.0 GHz with no Turbo core tech and a slight bump in voltage. When I resume my computer, CPU-Z and other programs report the speed going down to 3.7 GHz with Turbo core (I think it goes up to 4 GHz) and stock voltage.
I'm on an Asus M5A97 R2.0. I know it's not a proper motherboard for overclocking, but it'll do till I can afford a new one in the summer. I've been emailing Asus and they suggest that I replace the RAM with something else to test which is ridiculous because a) I don't have any lying around and b) It's not RAM related.
I'm not sure what else to do besides giving up. Any other users have the same issues or any sort of advice?
Are you using AMD Overdrive or your BIOS?
Disable cool n quiet. Disable C states.
