I have been using Lookingglass for a while on my gentoo system. I had a recent system update and broke lookingglass though I have no idea how. My virtual machine is running without issue, but when I launch lookingglass I get the following:
[I] main.c:996 | run | Looking Glass (B1-rc6-6-gb979752989+1)
[I] main.c:997 | run | Locking Method: Atomic
[I] egl.c:187 | egl_initialize | Double buffering is on
[I] egl.c:201 | egl_initialize | Multsampling enabled, max samples: 4
[I] main.c:902 | try_renderer | Using Renderer: EGL
[I] main.c:1183 | run | Using Clipboard: X11
[I] spice.c:197 | spice_connect | Remote: 127.0.0.1:5900
[E] egl.c:428 | egl_render_startup | Failed to create EGL surface (eglError: 0x300b)
[I] main.c:1259 | run | Waiting for host to signal it's ready...
The client exits back to the command line with no further information. The only argument I am passing is “-a”.
I have tried rebuilding the entire client but continue to get the issue. Can someone point me in the right direction. I’m sure it is something simple I am missing which changed with my most recent system update but I cannot figure it out for the life of me.
Thanks
drc
